Question about HP DeskJet 952c InkJet Printer
Hp 952c only prints 1/2 of page. error code 90020303 OS is ubuntu
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Posted on Oct 13, 2008
  • 163 Answers
SOURCE: Officejet 4300 series printer would
hi there...open the printer panel and then clean the printing rod properly (rod on which the cartridge runs). check doing this first....if it does not work then you will have get it serviced from the repair centre of HP.
thanks
Posted on Jan 02, 2009
sanjay_tech
  • 20 Answers
SOURCE: HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Posted on Jan 26, 2009
FixinFax
  • 3085 Answers
SOURCE: My HP 1300 does not always print a complete page
Remove the paper tray and toner cartridge.
Clean the gray roller with isopropyl alcohol.
Posted on Jul 30, 2009
  • 99 Answers
SOURCE: My Hp PRINTER just started printing 1 page on to multiple pages ?
check paper size settings on both your pc and printer manu.
Posted on Sep 30, 2009
My printer starts printing then immediately pauses several times up to 30 seconds each before completing the page.
Your mainboard is damaged. you must bake it! search at google about how to bake a board.
Apr 25, 2016 | HP DeskJet 952c InkJet Printer
Hp Printer 5650 Printing Failure My system: Mac 7300 upgraded with MaxPower G3, and a PCL USB & Firewire card. An alternate system tried was a Wallstreet G3 laptop with a USB card. Both systems were...
Print failure is a very common issue faced by users while printing a document. There could be many issues if you are unable to print from HP printer. But you don't need to worry, we are here to help you out.http://www.hptechsupportnumber.com/ HP Tech Support Phone Number 1 877 645 7494 HP Helpline
Feb 28, 2017 | HP DeskJet 5650 InkJet Printer
How do i clean my head on my hp deskjet 952c printer?
just full ink cartridge and wipe print head under it, this model not same with other model that the printer head separate with ink cartridge.
Mar 25, 2010 | HP DeskJet 952c InkJet Printer
Have new ink cartridges, however when I print a test page, nothing but the windows logo prints
You mean, the black color is completely absent from the printed page? Either the black cartridge is faulty and needs to be cleaned, or (less likely) the cartridge carriage is faulty.
Try running the "Printer Head Cleanup" routine from the printer manager maintenance menu.
Aug 28, 2009 | HP DeskJet 952c InkJet Printer
Printer won't print the first red light is blinking sounds like it trying to grab paper but it's not
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP DeskJet 952c InkJet Printer
How to remove the top of the 952c to get to the ink reservoir.
HP 952c = Deskjet Printer
Like ALL HP deskjets of this design:
Turn Printer ON (allow for test cycle), then lift top hinged panel.
Print cartridges will be parked in protected area to the right.
When top panel is lifted, they will move out for easy access.
They will NOT move out if printer is OFF.
So Please turn ON as first step.
Best to install new cartridges as opposed to cleaning.
If cleaning, utilize software option for clogged cartridges.
If they are leaking, replace them with new cartridges.
All this is available on HP web site.
Aug 04, 2008 | HP DeskJet 952c InkJet Printer
HP 952c
hi!
Try to cancel your document in the printers menu even if you restart the pc or the printers memory stores the previous command.
1.The idea is that printers has its own memory unless you cancel the document that you print.
e-mail me at wendel_tenebroso@yahoo.com if the problem persist
Apr 08, 2008 | HP DeskJet 952c InkJet Printer
Print page comes out blank
If the cartridges are old too this may be a problem. When ink gets old it can clog the cartridges. If they are old replace them with new ones. If they are new ones did you peel the protective covering off before you inserted the cartridges? Hopes this helps
Sep 16, 2007 | HP DeskJet 952c InkJet Printer
Multiple page printing
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Feb 03, 2007 | HP DeskJet 952c InkJet Printer
HP DeskJet 952c InkJet Printer Logo
115 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
