Question about Microsoft Windows XP Professional SP2C for PC
I have windows xp 64bit and iam trying to use 2 slots of 2gb memory ddr2 and instead of 4gb memory iam getting as a result 2.43gb how can i solve this? i have an asus pb5
  • Stephen Wilkins
    Stephen Wilkins May 11, 2010
    check the Memory QVL at asus.com an i think you mean the P5B
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    What do you get if you try installing each module individually?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
It looks a little low - but two possiblilites... the motherboard's chipset does not support more than 3GB of ram or you have not configured your ram correctly in your BIOS setup.
Restart computer and press whichever key it asks you to so you can go to Setup or BIOS config.
Look in the memory section, advanced chip set section or if necessary just go through all the options until you see the map memory hole... this allows the BIOS to see more memory.
But I think you will find it is your chipset. You could try flashing the BIOS to the latest version --- but that's another story.
Posted on Oct 05, 2009
2*2GB (4GB) ddr2 shows up as 2*1GB ddr2 (2GB)
It could be a problem if you are running a 32 bit operating system. I know that there is a limit of around 2gb on any 32bit windows install. this can be fixed by installing a 64bit version, IF your hardware supports it. You would need a 64bit cpu to install 64bit windows. If this is not the reason you are having the problem, the only other reason that would make sense would be that your motherboard doesnt support more than 1gb of ram per DIMM hence it shows that two are insalled but can only use one gb each. This i think is the more logical answer because I think the limit on GB for win 32bit was more like 3gb. good luck
Oct 08, 2012 | Intel DG43NB Motherboard
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
How many memory slots on a aspire x3200 motherboard
It has 2 slots. The memory type is ddr2 with 240 pins
Details:
Acer Aspire X3200-Quad SpecificationMemory Type:
DDR2
Memory Speed:
PC2-6400
Memory Type:
Non-ECC Non-Registered,
Memory Slot(s):
Max. Memory Per System:
4096MB (4GB)
Max. Memory Per Slot:
2048MB (2GB)
Install Memory in Pairs:
Not Required
Mar 22, 2011 | Computers & Internet
How to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Jan 31, 2011 | EliteGroup GeForce6100PM-M2 Motherboard
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
DDR3 RAM
According to your description you have 4 memory slots and each memory slot can hold
DDR2 PC2-6400
DDR2 PC2-8500
DDR2 PC2-5300 with a maximum of 2GB per slot.
This board does not support DDR3.
I hope this helps your memory question.
May 01, 2009 | Acer Computers & Internet
Memory Issue
yeah you should upgrade. Windows xp 32bit only support up to 3gb memory. You should upgrade to 64bit.
And your specs? Yeah it can run 64 bit operating systems or if you like, use Windows Vista x86 or x64 with Service Pack 1.
Sep 24, 2008 | Microsoft Windows XP Professional x64...
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Open Questions:
See all Microsoft Windows XP Professional SP2C for PC Questions
Microsoft Windows XP Professional SP2C for PC Logo
78 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
