Question about Estate TGDX640JQ Gas Dryer
When you first start the dryer it will light and burn for about 3min then go out. then try to relight. all that come on is the ignitor
  • 304 Answers
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when fully cooled down and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Posted on Oct 03, 2009
Need to relight pilot light on MDG6200AWW gas dryer.
That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
Mar 28, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Maytag dryer got wet motor still runs but gas won't fire
if the dryer is gas you must relight the pilot light or (if it has one)the ignitor is no good if it got wet also you could dry off the igintor or replace it.ignitor or pilot light will be under a small door on the back of the dryer about where the gas line goes into the dryer.jaykra
Aug 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 90 series propane gas dryer
Hi, You should not have a pilot light, There are electronic ignitors on the dryers. Unless this dryer is 40 years old, just start the dryer and the heat should come on.
If the heat does not work, there must be another issue.
Please let me know if I can help you further.
Thanks
Vic
Jul 21, 2009 | Kenmore 63942 Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
How to manually relight a Goodman® GMS9/GCS9 Single-Stage, Multi-Speed Gas Furnaces
You should NEVER attempt to relight manually this furnace. Serious burns could be the result. This furnace has an electronic ignition and should light by itself. If it does not light you may have a bad ignitor. These are usually around 30-50 US dollars.
Jan 28, 2009 | Goodman GMS90703BXA Heater
3 yr old amana gas dryer not working
i would replace the coils mounted ontop of the burner valve. they're overheaating nad not opening the valve after heated.
279834 twenty bucks. comes as a set replace both coils!!
Mar 10, 2008 | Dryers
Estate TGDX640JQ Gas Dryer Logo
105 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
