Question about Whirlpool Dryers
No heat on our clean touch electric dryer, it turns and blows air but it does not have heat
  • Whirlpool Master
  • 7,482 Answers
Sounds like the problem is you have a faulty heating coil or thermostats.
Remove the back of your dryer and located the air tube that goes from the blower to the drum.
Normally inside the air tube you will find the heating coil and the thermostats.
I hope this helps
Posted on Oct 03, 2009
No heat or air blowing inside unit
Are you sure you dont have a clogged Dryer Vnet?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Feb 09, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Dryer heats in a 'no heat' selection
it sounds like you have a grounded heat element and the heat will stay on all the time,very easy to check,unplug the dryer,pull the two wires off of the heat element,with a meter touch one lead to the outside metal cover of the heater and the other lead to one of the element,then check the other side of the element the same way,if it shows continuity on one end of the element it's grounded and needs to be replaced with a new heating element.and every year or 18 months you have to clean out the dryer,i use a shop vac and a leaf blower,unplug the dryer,remove the bottom panel,remove the lint filter and the metal duct that the filter slides into,vac up all the lint you can see,brush out the hole where the filter goes and with a long thin screw driver dig out the lint that's in the right and left sides of the plastic slots where the filter slides in,now with the shop vac set it to blow and blow all the lint from the back forwards and blow the motor off and vac up the lint,after you clean out the cabinet go to the back and remove the vent line from the dryer,stick the leaf blower into the vent line and blow it out to the outside,if you do this every year you'll have less problems with the dryer,your clothes will dry on time and you don't have to worry about a dryer fire.
Feb 01, 2014 | Kenmore Elite HE4 Electric Dryer
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Dryer works but is only blowing cold air. just bought the dryer last year and have already had it repaired once.
my Samsung was in a flood(so solution may only apply to floods), changed heater assembly, still blowing cold air, turned out to be the little black box on the generator, took box cover off,cleaned the connectors in box and voila...instant heat
Nov 28, 2009 | Samsung DV448AEE Electric Dryer
My dryer PYE4557AYW,gets to hot! When U touch below the door??
it sounds as though the heater protection thermostat is stuck closed and wont regulate the heating
May 02, 2009 | Maytag PYE2300AY Electric Dryer
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Blown thermal fuses
I would think not. The MAIN cause of that fuse blowing is lint build up. Turn the dryer on and put your hand on the outside of the vent duct. Is the air blowing hard? If so, you will probaly be ok, if not maybe your blower wheel needs to be replaced...
Dec 15, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
