Question about Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
The air compressor won't come up to speed when first starting and keeps blowing the breaker however after several attempts it will eventually work fine
  • mrbill68 Oct 03, 2009
    is their any way that I can trouble shoot this down schematics with voltages or something. the pump doesn't make any noises and the engine was replaced before I bought it because it was having the same problem
    How do I identify it and where do I get a replacement
  • 6,982 Answers
Sounds like your start capacitor has failed. It's job is to "kick start" the motor to keep it from bogging down and doing exactly what your is doing.
Posted on Oct 03, 2009
  • Richard Scordino Oct 03, 2009
    Funny, I should know exactly what the test is but after doing a few a
    long time ago, and then over the years, just changing them because the
    symptoms are pretty much all the same, I can't remember. The capacitor
    is usually located under a half round cover most times on the side
    towards the back on the motor housing. depending upon the size of the
    motor, the capacitor is usually about one inch in diameter and about
    three inches long though some aren't perfectly cylindrical. if still
    charged, it can knock you on your **** so be careful working with it.
    Most carry a part number right on them and many are available from any
    electric motor rebuilder.
  • 1,068 Answers
Without being there to test it with the meter i can't say for sure but from my experience when a motor is starting to go bad. meaning it has a worn spot on the armature of the windings it will cause a excessive draw and make the fuse blow. now why it may be working after several attempts is because it is heating up and metal expands when hot and stops the increased draw because the clearance has shrunk because of the expansion of the metal.
also the compressor engine(air pump) may be causing it because it is starting to bind up and after several attempts it losen enough that the motor can keep it turning. but i would think you would hear a noise coming from it if so.
to check if that is the issue you need to tke of the belt from motor to air pump and spin the air pumps pulley to see if there is eccessive drag on it.
if so you will need to find out why the air pump is binding by checking the crank and rod and piston(s).
let me know if you hve any more question! good luck
Posted on Oct 02, 2009
Air Conditioner trips the 110v breaker, only when the outside temp is above 90 degrees. Unit has been checked several time and the circuit board has been replaced, but has fixed the problem of tripping the...
'Breakers' - are tripped because they are exceeding their amp limits.
The 'hotter' it gets outside - the 'harder' your AC has to work - and under normal circumstances this is not a problem - but when you have a fan motor or a compressor that is starting to 'break-down' (electrically) - often the AC's amp draw will exceed the limits of the breaker - thus 'tripping' the breaker.
I would suspect either the fan motor or the compressor is causing your breaker problem.
Eventually - the component (either the fan mtr or compressor) that is 'going bad' will go out completely and your breaker will 'trip' and not stay on when you try to reset it.
At this point you will need a Service Tech to determine which one is bad.
There is a possibility that your condenser coil (the one that blows hot air) is 'dirty' which will also cause a problem similar to the one you have - but it is less likely.
Also - if you've had the AC 're-charged' lately - it's possible you are in a 'over-charged' condition - but again, this is not very likely.
hope this helps.
Jun 06, 2010 | Dometic Rooftop RV Air Conditioner
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
AC running inside but outside unit not....keeps blowing breakers
Hello my name is Heath it will be my pleasure to assist you. The compressor is locked up. What you could do is try a hard start capacitor on the unit which would probably get the compressor turning without blowing the breaker.
Apr 27, 2010 | Carrier 38CKC036 Air Conditioner
Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Jun 16, 2009 | Ingersoll Rand 2545/7100 Electric Air...
One unit runs a while, powers down, other unit blows transformer
you say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
May 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Compressor intermittent
Sounds like a bad thermostat. Make sure you turn off all related breakers and disconnect switches before attempting to replace it. Good Luck!
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5 Logo
83 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
