Question about Compaq Refurbished 280WATT POWER SUPPLY FOR PROFESSIONAL WORKSTATION 5100 Power Supply
i wants to know about components based calculation of output capacity
( output watts ) of an computer atx smps
if i am not wrong the way of components based calculation like this
for example if we are using 2nos of power transistor mje-13007 having max output of 80 watts each it means 80x2=160 watts ????????
if im right then plz check this link they say`s this is 200w atx smps but they are using power transistor 2sc4242 ( 400v and 40 watts means 40x2= 80 watts ) ??????????????
plz guide me i m confused
satish rajput
    SATISH RAJPUT Dec 28, 2007
    i m agree with u ,
    in fact i m also findout the same answr
    now i know that if u wants to findout the max capacity of an psu u have to put the load according to voltage current etc , and with the help of amp meter u can see the out put results
    thanx dear
    satish rajput
  • gavasbalan Feb 19, 2009
    what is smps?difference between ordinary smps to computor smps?
    pls, give me good answer
    by gavas.
    Problem Solver:
  • 10 Answers
Every device can be safely operated upto allowable temperature. If you design to remove heat, then for same power, temp would be low or for a particular temperature, it can cater more power handeling capacity. Here is the trick.
If the heatsink and force cooling is provided, the power rating can be easily increased. And this is the trick the company utilize the engineering to overdrive components. Even if insted of using high current schottky rectifiers like MBR3045WT (15A Each Channel) in low voltage side, they solder cathod of 1N5822 (3A Capacity)to metal plate and screwed to heatsink. But the transformers capacity is also reduced to using high frequency of SMPS 130KHz insted of earlier 66 or 33 KHz. I also found Good design Frontech 600Watt SMPS without HV line filter choke and without low voltage filtering capacitor.
The only testing is to connect load resistance to each voltage so that it must not fail. Another thing I can recomend, to check the bulky SMPS (heavy or weight high) during purchase as seal opening voids guarantee. Of course, seeing through vent hole will give you some idea if you are aware about electronics.
Posted on Jan 30, 2010
  • 254 Answers
Maximum output of any smps is not based solely on the type of power switching transistors used. One of the parameters which will be crucial is the Ic (Max collector current rating). But this by itself isn't the lone determining factor either.
Other design factors which will come into play are the switching transformer, its size and windings. A smaller transformer and smaller wire gauge windings will generally mean lower max power output.
Max power output measurements probably require a set of load resistors, volt and amp meters, monitoring the 3.3, 5, 12 volt lines.
I'm not an engineer, but have had numerous computer power supplies apart, repairing some, junking some. Quality of construction or lack thereof is generally obvious. PC Power and Cooling probably builds high quality units. There are plenty of cheap, low cost power supplies which frequently die after a year or two, sometimes taking a motherboard down with it.
Posted on Dec 22, 2007
What wattage&ohmage of speaker is best
Your amp has an output power of 50 Watts per channel into 4 Ohms speaker. It is designed to work with 4 Ohms speakers, and it will be best to slect 4Ohms impedence speakers to connect with this amp. Consider the Watts capacity of speaker too. It must be not less than 50Watts. In short, you have to select 4Ohms speakers, haveing more than 50Watts power handiling capacity. Remember, as Watt capacity of speaker increses, the cost will also increase considerably. OK.
Jan 19, 2012 | Teac A-H300 Amplifier
How to calculate and convert three dimensional volume capacity
Want to know the capacity of your appliance, say a microwave, fridge, freezer, pot, hot-water geyser?
Or bigger volumes such as a swimming pool or cylindrical water tank?
The manufacturer states volume as cu.ft but you work in liters?
You see liters but think in Gallons?
The table graphic shows all these conversions as a base to calculate from.
Also included is a brief guide to measuring and calculating.
on Nov 28, 2017 | Miscellaneous
Hello Mkmanishbit2 hi, SMPS means switch mode power supply. The capacity of an SMPS unit is from 200 watts to 1500 watts, and some can be 2000 watts. Now for your Gigabyte Motherboard, a standard 350 watts unit will do, for medium end gaming, 500 watts will be enough, and for high end gaming, use the 800 to 1500 watts unit. Reminder the higher the watts number the higher the price, but the safer it becomes.
Nov 30, 2010 | Intel Motherboard
Dimension 3100 Won't POST, getting amber flashing amber light at front panel and on the mother board getting steady light near the cmos battery note under the light says cr3h1 re-seated cpu and cards,...
I concur with your diagnoses.
Weak power supply due to a weak, or failed, voltage power rail.
There are three main voltage power rails for your Dell Dimension 3100 power supply.
1.The 3.3 Volt rail
2.The 5 Volt rail
3.The 12 Volt rail
Newer computer power supply's are doing away with the 3.3 Volt rail.
Your power supply has,
16 Amps on the 3.3 Volt rail,
21 Amps on the 5 Volt rail, and
21 Amps on the 12 Volt rail.
These are the main power voltage rails.
Voltage times Amperage = Wattage.
You have a power supply, that is rated at a maximum output of 400 Watts.
1) ALL the lights use less than 1 Watt.
2) EACH fan uses 2 to 3 Watts
3) A typical processor uses 55 to 125 Watts.
(A typical Intel Pentium 4 HT processor, Model 640, (3.2GHz), uses a maximum of 84 Watts,
With a weak, or failed voltage power rail you don't have enough power to turn on the processor.
No processor running there is nothing to run the operating system. (Windows XP is an example of an O/S)
The harddrive just sits there, and spins, or will spin a few times, and stop.
What causes this?
1) Cheap quality power supply, (SMPS), installed by computer manufacturer. Cheap components are used in the power supply. (Electrolytic Capacitors, gauge of wiring, rectifier bridge, and so on)
2) Inside of computer, and power supply hasn't been cleaned on a regular basis.
Causes havoc inside the computer.
The processor fan builds up with dust, dirt, hair, etc, and the cooling capacity drops tremendously. Eventually the processor turns off. (BIOS turns it off)
It's a Fail safe feature that is built-in, to keep the processor from burning up.
Before it get's to the stage of overheating, and turning off, it calls for more power from the power supply.
The power supply works overtime to keep up.
When the inside of a power supply, and it's cooling fan are clogged with the above mentioned gunk, the cooling capacity of the power supply also drops tremendously.
The heatsink's inside the power supply cannot get rid of the heat. The fins are clogged, and air cannot rush through them to disperse the heat.
When the blades of the fan, and it's center hub become clogged, the cooling capacity drops due to not enough air is passed.
Heat = Wasted Energy, and the power supply strains to keep up. Eventually components inside the power supply start to fail, or fail.
(Electrolytic Capacitors are usually the first to go. They are the weakest link)
Dec 26, 2009 | Dell Dimension 3100 PC Desktop
I only have the big speaker not 2 small ones that actually go with it so I'd like to know how to hook it up to my pc and what other speakers may be compatible
Connect the sound card of the PC with a recommended amplifier and then connect your big speakers to the amplifier, you can get the big speakers working. Note that the amplifier watts must be in respect to the maximum watts of your big speakers. Either the amplifier should have more watts producing capacity than your speakers or should be of the same watts in order to give you full output volume.
Sep 12, 2009 | Audio Players & Recorders
Component details
You can install Windows 95, I'm not sure about Windows98
Aug 25, 2009 | Computers & Internet
Dont know how to find the watt usage of the motherboard ?
There are many power supply calculators out there. As long as you know what the components are on your computer, you should be able to find max power usage by inputting all the components. Google search terms:
power supply calculator.
Jun 10, 2009 | HP Pavilion a705w PC Desktop
How can we caculate the energy needed by an air conditioner?
It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
Example 35000 btus / 2500 watts = 14 EER
If you know the capacity,btus and EER you can calculate the watts, capacity / EER
Example 35000 btus / 14 EER = 2500 watts.
EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Speaker watt
A series parallel network of four (4) 60 watts speakers would give you the same ohmage/impedance but with 240 watts capacity. Just two in parallel would give you half the ohmage/impedance but 120watts capacity or two in series would give you double the ohmage/impedance with again 120watts capacity.
Incidentally, if you bridge the power amp, you double the amp's output but only mono.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Audio Players & Recorders
Computers & Internet Logo
1,958 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
