Question about LaCie Ethernet Disk mini USB 2.0 External 250GB Hard Drive
PLEASE help me! My Lacie External Hard Drive is NOT powering on...all my important data is on there - need help!!!!
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Lacie 1tb only showing n 30g room
Hey there,
A hard drive, especially a new one, might need to be formatted before use to show the proper amount of data available for use. Sometimes a hard drive might malfunction and not show the proper amount of free space. formatting should also solve this problem, Before you go and format your hard drive understand that by formatting it you will lose all data that is stored on it, so if you have anything important, take it off first.
here is a detailed guide to reformatting your hard drive based on your operating system
http://thelightroomlab.com/2009/01/formatting-an-external-hard-drive/
Hope this helps!!
Mar 16, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie External Hard Drive FAILED
Just format the drive and u will be able to use it.
Jun 07, 2010 | LaCie (301015) 120 GB Hard Drive
I have LaCie 500 GB Exernal Hard Drive. I was transferring some data from my computer into the hard drive. The hard drive fell off and stopped working. When i connect it to power, the power light doesn't...
Sounds like the power supply in the external case has gone bad (or going bad)...
If you have another external case, AND the drive itself is not damaged, you can move the drive to an external case.. Alternately, depending on the connection (IDE/SATA) you can move the drive internally to your computer.
Jul 20, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie Big Disk Extreme 1TB Hard Drive - continuous beep, no power
Hi, Lacie isn't very forthcoming with beep codes but it definitely means one of the two. You can try moving the hard drive into a new enclosure, if it works it was the enclosure, if not the HDD. Hate to say it but warranty on these drives is a moot point the moment unique data is stored on them as you can't even diagnose the problem properly without voiding it and no drive manufacturer will waranty data. If you have no unique data and it's under warranty, send it back. If you have unique data on it that you value, take it to a local computer store and have them move the drive to a new external enclosure and test it. If it works, you're done. If it doesn't, you've confirmed that the HDD is faulty and you will need the help of a data recovery Pro. If the latter is the case, reply by commenting here with your location (country, state city) and I'll recommend a closeby facility for you. Chris
Jun 04, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
External Hard drive clicking sound and unable to view contents of
First check the LaCie power supply. I have a D2 HARD DISK EXTREME 250GB model 300770 that had this exact problem. I swapped out the power supply for the higher wattage unit from LaCie and presto, the drive functioned properly. Not saying this will fix your problem but I have personally had this exact problem. If not take the drive and mount it in a PC IDE/EIDE disk slot and see if you can mount the drive and recover your data (points to LaCie controller problem). Note opening the drive invalidates your LaCie warranty. Also note the warranty on my drive was one years and had long since passed. If that does not work, your last alternative it to use a disk data recovery service but that is big $$$$s. Bon Chance!
Feb 20, 2009 | LaCie (300770) 250 GB Hard Drive
Computer external hard drive problem
If the hard drive still spins, then the data can be saved. If there is a near by computer store, explain your problem, and they can take apart the drive and probably but the data on a new drive for you. If you want to try this yourself, you will need to take apart the outer enclosure of the Lacie drive. Then unplug the hard drive, and either put it in another similar enclosure (requires taking that one apart too) or buying a new enclosure.
Regards,
Sam
Was this information helpful? Please rate it!
Dec 02, 2008 | Computers & Internet
Lacie Big Disk -High Speed UBS 2.0
If all you need is to get the data off your HD at this time and work later on fixing it. Open "IPConfigurator" and it will find your Lacie. At this point you should be able to open it via an internet browser, select HTTP, enter username and password. Then select the item and it will open/download and you can re-save it or view it from the internet.
Aug 02, 2008 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie 1 TB External Hard Drive
EMAIL ME AT : fixya-expert@live.com and i will send to you instructions how to recover data
Jan 27, 2008 | LaCie d2 Extreme 250GB External with...
Lacie 1tb external hard drive
As a precaution, backup your data to another machine, in case the external drive is developing problems which would get worse and essentially "lose" your data. Does it do this on other machines other than yours? If so, it is developing problems, which, as said, could be deadly to data. If it doesn't foul up on other machines, then something is afoul with something on your machine. Various problems are reported with sleep mode wakeup. Could you disable the sleep mode function? You might see if there is an O/S update for your Mac which addresses this problem (waking up the USB ports & connected devices).
Sep 15, 2007 | LaCie d2 Extreme 250GB External with...
LaCie Ethernet Disk mini USB 2.0 External 250GB Hard Drive Logo
125 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
