Question about Canon PIXMA MX850 Multifunction Printer
Blank pages from Canon MX850 scanner
When I scan a stack of pages from my document feeder, I get a blank page after every printed page. I am scanning to my Mac OS10 desktop
  • 154 Answers
Try Removing the printhead of your printer and putit back, and do the clean nozzles and printhead alignment.
Posted on Oct 02, 2009
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
I have a Canon MX850, I don't understand why my big black ink cartridge is full and it uses only the small one, how can I change to use the big one?
The printer use big PGI-5bk cartridge to print documents and text.When you print photos or some other pictures printer use small CLI-8bk cartridge because this cartridge has a photo ink.If you print text and it print blank page that mean the nozzle on PGI-5 cartridge is clogged.Try cleaning test on maintenance menu on printer.
Oct 29, 2009 | Canon PIXMA MX850 Multifunction Printer
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
"Skip Blank Page" Set to 0.1% Yet still skips pages with footers and headers
We have the same problem where I work. We use a black texta and draw a line down the middle of the page. This gives the scanner a point to pick up apart from the minimal text at the top. However, this will only work if you are happy to have a line on your scanned document!
Apr 09, 2008 | Canon DR-9080C Path-Through Scanner
HP All-In-One HP C7280 (Ink Jet Color Printer/Scanner/FAX)
on that web page look if u have any thing which says printable version or printer friendly
try with that and check
Mar 07, 2008 | Office Equipment & Supplies
Printing blank pages
Make sure your set to "print" and not scan. The blank pages may be a 'print' of the lid on your scanner top
Feb 20, 2008 | HP Photosmart C4180 All-In-One InkJet...
Canon PIXMA MX850 Multifunction Printer Logo
234 people viewed this question
old marine
old marine
