Question about Empire ECS BF-30 Infra-Red Wall Mounted Panel Heater
Pilet light keeps going out after 1 to 2 hrs is this something I can fix
  • 80 Answers
Replace the thermocouple.
Posted on Oct 04, 2009
Having problems with my fryolar pilet goes on but doesnt stay on it keeps going out what can I do to fix this problem it really isnt that old if you can please help me I would apprecated it
Sounds like your thermostat could be bad... It's not holding temperature right, which is what the thermostat does for you... It could also be the thermocouple, which tells the fryer to stay on itself....
If you need parts or additional help, please call Paul or Ray at Restaurant Equipment Outlet, 888-542-5959, Cincinnati, Ohio. We can order parts and have them there in 1-2 days.... Thanks, Susan
Sep 08, 2011 | Imperial IFS40 Deep Fryer
Pilet light goes out after water is heated and has to be relite how to fix
try tapping the pilot assembly when you have it lit to see if the flame gets straight the flame cannot be lazy like dancing around its gotta be dirrect if it still goes out get a new thermocouple
Aug 17, 2010 | Heating & Cooling
It just stopped working last night. Gas kitchen stove works fine. Are there pilet lights on these things?
if its gas, it has a pilot light. the most likely thing is the thermal coupling is bad. if it is bad, burner flame will not turn on. it senses the tempurature to send gas to light burner.
Aug 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Im trying to lite the pilet
This dryer has no pilot light. When you turn dryer on the igniter turns on and lights gas. If yours is not igniting, you could have a bad igniter or a bad heater cavity switch located behind back panel attached to dryer vent area, has two wires connected to it.
Jun 10, 2010 | Estate TGDX640JQ Gas Dryer
Regular dry it gets hot then stops
If the ignitor tries to light the flame after it quits, the coil on the main valve is likely bad--a common problem. Good luck!
Apr 13, 2010 | Whirlpool LGR5636L Gas Dryer
Pilet light in the oven keeps going out
Try cleaning it with a tooth brush, tiny bits of residue build up on there. If that don't work you gotta replace it or remove it and inspect the orifice. Most of the time the gas valve is faulty on these. But time is getting on and stuff happens. LOL
Jan 28, 2010 | GE JGBS03 Kitchen Range
1999 CHEVY SILVERADO WARNING LIGHTS KEEP FLASHING
I had something similar happen to my 2006 and it was a short in the fuse box itself. It cost me about $500 in all from the dealer, but you may be able to just get a used one at a junk yard and back then I don't think you have to have the dealer reprogram everything. Good luck.
Oct 26, 2009 | 1999 Chevrolet Silverado 1500
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have sound and no picture. Red light on in front of tv indicating lamp. Can be fixed w/o repairman?
Yes the Lamp can fail within that time frame. Much of it depends on how many hours the set is running. Most Lamps have a 3000 to 5000 hrs of life. But with any Halogen style Lamp, this is not written in stone.
Hope this helps,
Skyassoc
May 11, 2009 | Mitsubishi WD-65833 65" HDTV
Maytag DG612 gas dryer does not heat up. what should I check. does a pilot light need to be lit?
unplug your unit.You have an ignitor no pilot. Just because they glow they are not good. Do you have a meter and an amp clamp? Test all the limits and thermisters for continuity. If you find one with no continuity it is bad.
Jul 12, 2008 | Maytag Dryers
Empire ECS BF-30 Infra-Red Wall Mounted Panel Heater Logo
99 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
