The power supply is shorted or overloaded that's why it buzzes. Horizontal output IC and/or flyback is bad.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below. A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition. The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection). The only way to determine the real cause is : By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound orpicture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
I have found the horizontal output transistor (HOT) to fail and then causing the flyback transformer to fail. Both parts are under $30 total, but the danger is in replacing them. Make sure you discharge the flyback to the ground strap.
cant control the tv from remote control,tv seems to control it self very fast and always mute.can i...
(More)
CANT CONTROL THE TV FROM REMOTE CONTROL,TV SEEMS TO CONTROL IT SELF VERY FAST AND ALWAYS MUTE.CAN I REPLAC THE CONTROL PEICE ON TOP TO STOP THIS! NEED HELP PLEASE.
I need help either resetting an RCA 36V430T or help with removing the parental controls. I have...
(More)
I need help either resetting an RCA 36V430T or help with removing the parental controls. I have tried the instructions listed in the user manual and online without success.
RCA F36650 I think the volume button on the top is bad. How do I remove the top control assembly?...
(More)
RCA F36650 I think the volume button on the top is bad. How do I remove the top control assembly? The back of the TV is already removed
