Question about Craftsman Garden
3/4 hp 17 257.796040 semi automatic line feed the spring for the linespool is lost
  • 437 Answers
Looks like you have a Sears product. Go to www.partsdirect.com. Put in your model number 257.796040 And you will find a parts list and diagram for the unit.
Posted on Oct 03, 2009
22 semi auto rifle jamming
Often with semi-automatic rim fire rifles, the most common cause of jams/failures to feed are related to improper cleaning. Most of these low-powered rifles utilize a blowback action to fire, and thus require a clean breech and chamber to provide proper obturation of the cartridge. Give your rifle a thorough cleaning, including a detail strip and clean. If you are experiencing other types of stoppages such as failures to extract or failure to feed, you may be experiencing a mechanical issue such as a worn extractor claw, or a weak magazine follower spring.
Feb 28, 2014 | Marlin Model 60 .22 Cal Rifle
Remington field master 121 . will feed, fire and extract but will not eject
If this is a semi auto clean the gas passages. If it is a pump or semi auto check that the bolt travel moves full length. Make sure the extractor groove is clean and the spring that pushes on the extractor is clean.
Aug 29, 2013 | Garden
Can somebody help with clutch not engaging, starter works won't fire
if its semi automatic then youll need to rebuild the clutch which is inside the motor. if its not semi automatic, then pull the top end off where the clutch cable goes into the top end, and there will probably be a broken spring. or you just need a new clutch cable
Aug 03, 2013 | Yamaha 2005 Raptor 80
HP officejet 4500 will not print all lines on a page
You need to clean your printhead. In your manual is explained how to do this. This is most of the time a semi-automatic process.
Nov 15, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
I need to find out how to convert a yugo sks to an automatic. it is semi auto but i want it to be automatic. Its a 7.62.39mm. Can you help?
Pay the feds $200 tax stamp and become one of their most watched, then go out and find a conversion kit, consisting of auto sear, selector, trigger, hammer, bolt carrier, springs, and whatever else you need, install it, you will be all set, then find a couple thousand rounds to feed the thing. And become hated by everybody within ear shot of your rifle.And every local police wanting to see your federal papers. Not worth it in my book. Fun yes, but not worth the aggravation. Are you in the US?
Mar 13, 2010 | SKS Rifle High-profile See-thru Scope...
When I use the automatic feed a blank line appears in t
BLANK or BLACK?, if it's Black, clean the SCANNER GLASS.
Aug 05, 2009 | HP LaserJet 4345mfp Printer
Feed switch came apart, seems to have lost spring out of wirewhip
sounds like you lost a spring i would just get a new gun
Jun 26, 2009 | Welding Tools
Automatic feed gives a white line in copy or scan
Although this problem would normally show as a black line on the copy, it's quite possible that there is something white (i.e. a piece of tape or paper) stuck on the scanner where the page feed passes through. Clean this area carefully with a soft cloth.
Jun 01, 2009 | HP LaserJet 4345mfp Printer
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
Semi automatic defrost button won't pop up
The switch is broken and needs to be replaced.
This happens a lot
Huum
Please remember to leave feed back .
This is the answer.
click solve please1
Dec 09, 2008 | Refrigerators
Garden Logo
272 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
