Unable to locat and select the AV channel on new LCD HD TV
Am having trouble locating the AV channel to watch a DVD. The LCD is connected thru the DVD player as per our other TV was. When I go into plug and play I only have TV and DTV for selection, I can see the AV channels there but are unable to select them.
  • Anonymous Mar 29, 2014
    Will not stay on channel selected. Only way to change channels is to select from menu, turn TV off and then back on. Will work for a while before starting to roll again.
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Posted on Dec 23, 2007
How do I watch a DVD with this tv. It seems like it is connected right but just showing static
Hi. By static, do you mean 'snow' image ? DVD players must be connected to AV inputs and selected as an AV signal, either by using the remote control, either using the local controls in the set itself. If you see, what you call static, means that your TV is on "a" channel without areal input. (antenna inputsignal).
You can use the local TV channel button (-), go all the way down below channel 1. There the AV inputs are located. Good luck.
Oct 13, 2014 | GE 27GT616 27" TV
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Unable to record from tv
I have the same problem and I called Zenith for support. I was told that the ZBR716 does NOT have a "tuner", so the only way you can record what is on TV is if, and only if, the TV has OUTPUTS (3 connectors), which could be connected to the ZBR716's inputs. But then you could only record what is currently being watched on TV. You could not record and watch something else, or set up to record something at a particular time on a particular channel, because the TV has to be on.
Unfortunately, I didn't look into this until some time after I bought the unit, so I can't return it. I was told to get a VCR/DVD recorder WITH a tuner.
I, too, had a VCR with a separate coax connection for the incoming cable tv,and it worked like your other one did.
My fault for not looking into it sooner, Circuit City's fault for selling me something when I was very specific about what I wanted and what I wanted to do with it.
you can call zenith yourself, go to www.zenith.com and hit the support page and eventually you'll find the phone number.
good luck.
Aug 21, 2008 | Zenith XBR716
Cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Televison & Video Logo
338 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
