Question about Dynex 32 in. LCD Flat-Panel HDTV
How to set up surround sound on dynex 32 LCD to
How to set up surround sound on dynex32LCD to Nakamichi 8.5 Sound space
    President:
  • Dynex Master
  • 1,779 Answers
Just use the L+R Audio Out from the jack panel on the rear of the set. They use RCA jacks.
Posted on Oct 02, 2009
My surround sound works when it is a dvd movie. How can this output when cable is on?
The program from cable system, must be surround sound in order TV set works as surround sound system
May 11, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Cant get sound through surround sound
There might be a setting that you need to enable to allow external audio to be used so the TV can switch to the surround sound.
Mar 01, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Unable to set surround sound to work
The media you are playing must have surround sound recorded or encoded on it in order for surround sound to play or occur. Get a DVD or CD that has surround sound stated on the label - otherwise the system defaults to stereo playback.
Oct 31, 2010 | Nakamichi AV-10 Receiver
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
No sound
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find
Typical repair for LCD TV is from $150 and up. Dynex is a cheaply made brand.
Jul 04, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex t. v. the volume control button increases
Make sure this is happening from two sources such as a dvd player and a gaming system as well. If it happens from two sources the speakers are more than likely not working or the sound board will need to be replaced. A cheap way of getting around a repair is by getting a surround sound and running a cablebox, dvd player, and/or your gaming system directly to the surround sound system using it for sound instead of the tv.
May 07, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How do i get my ps3 to run through my lg surround sound
Connect your yellow and red lead from the PS3 to the surround system, connect them to aux input. (the white lead is not needed). Then in the sound settings on the PS3, go to audio multi-output and change it to on. On your remote for the sound system press the input button until aux appears on the front of your LG HT303SU, and thats it, happy gaming.
May 18, 2009 | LG Televison & Video
37' Dynex LCD flat tv, sound doesnt work on some chanels.
There are few sound settings on most tv's the most common is D/K and B/G the one that you want is B/G it should be under tuning or sound settings.
If you have any questions please dont hesitate to ask
Nov 27, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Nakamichi AV-7 (issue with surround mode - prologic)
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Aug 28, 2008 | Nakamichi AV-7 Receiver
Nakamichi Sound Space 8 System
NEW CABLE FROM NAKAMICHI IS £150 . INSTEAD JUST CUT THE METAL SHIELD OFF ANY CD MINI DIN CONTROL CABLE WITH A JUNIOR HACKSAW AND IT WILL FIT PERFECTLY (IT ONLY GOES IN ONE WAY BECAUSE OF THE WAY THE PINS ARE LAID OUT!). I USED AN OLD MAC DIN PLUG BECAUSE IT WAS 3M LONG! WORKS PERFECTLY!
DS
Jun 01, 2008 | Nakamichi SoundSpace 8 System
Dynex 32 in. LCD Flat-Panel HDTV Logo
561 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
