A WESTERN dIGITAL eXTERRNAL HARD DRIVE FELL FROM TABLE. iT STOP WORKING THE BLUE LIGT STRT BLINKING AND NOTHING HAPPEN. cAN THOS HARD DISK BE SET IN AN ENCLOUSURE?
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Oct 02, 2009
I was just curious if there was a way to adapt this hard drive to be plugged into a usb port. Or how to connect it to a laptop as a second hard drive.
USB 2 or 3, yes, many shops sell adapters and enclousures. You can also buy a NAS enclousure and connect the drive to your network.
Sep 12, 2011 | Agi Western Digital Cavier Blue WD5000AAKX...
I have 1tb western digital external hard drive. It fell at the usb port got broken, so I went ahead and took it out of it's orginial casing. Placed it in a docking station and all i get is a blinking...
these have software in them for the board in the factory case ...you will have to use a data recovery software to recover contents then reformat the drive OR try installing it as a second drive inside the pc directly to the sata/ide cables not usb. good luck
May 08, 2011 | Western Digital My Book Essential 1TB...
External disc drive has stopped working States that I have to format the disc - It was working yesterday. 0 bytes on properties
It seems something happened to file allocation table of the disk partition, you could use a partition recovery suite to fix this, one good is Easeus Data Recovery Wizard or any similar suite that you know, good luck.
Feb 26, 2011 | Western Digital My Book Essential Edition...
MY WD HARD DRIVE IS ON, BUT IT WON'T SHOW UP ON MY COMPUTER. A BLUE LIGHT IS BLINKING IN A UPWARD MIDDLE KIND A WAY. I TRIED TO BRING IT UP ON MY LABTOP AS WELL, BUT THE SAME THING HAPPENED. HELP!!!
You can try to locate in disk management.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it and see ...
Cheers uttam
Jan 13, 2010 | Western Digital My Book Essential Edition...
Dear sir, i have a wd1600xmsb external usb. it fell flat on it's bottom on top of my cpu (about 1-1/2 ft. high). my computer cannot recognize it, but it's blue led light lits when it's plugged to the usb...
your disk motor is stuck and not turning the disks from being compressed from the fall. you will need to take it to a computer shop that agrees before they work on it they will be able to save your data. tell them exactly what happened
Dec 27, 2009 | Western Digital External USB 2.0 80 GB...
AC Adapter blinks once, but no power getting to hard drive
These drives are known for lunching the power supply within the unit itself. Depending on you PC configuration, you may wish to do the same as I did when mine went. The drive itself is a standard 7200 sata drive. If your motherboard has sata capability, and/or a spare sata connection, you can slave the drive into your pc, and end of problem.
Sep 19, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My 1tb disk fell from a table and it doesn'st work
Considering the fact that you can buy them from Western Digital, for an arm and a leg of coarse.  I would say look on ebay for a junk one with a bad hard drive and just swap it.  Other than that you can buy just an empty hard drive enclosure off ebay or newegg pretty cheap...around 20 bucks.  I am taking it your hard drive would probably be a SATA.  But before you buy, make sure the connectors will fit.  it will be long and skinny, which is IDE or short and skinny, SATA.
Mar 03, 2009 | Western Digital My Book Essential Edition...
Computers & Internet Logo
287 people viewed this question
David Payne
David Payne
