Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool accubake system model#RBD275PDS15 has trouble codes E6 & F2
    Guru:
  • 310 Answers
This could be either a problem with the keypad or the control. Here's the manufacturer's "recommended repair procedure":
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control.
... not so good, they want you to replace the keypad and if that doesn't work replace the control board ... both very expensive!
First I suggest trying to clean up the keypad ribbon connection into the control board ... this is free! We put a procedure on our website that describes how to do it, heres the link:
http://www.fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
If you come to the conclusion that the failure is due to the control board, we can have a look at it for you if your comfortable to remove it. We repair oven controllers.
Or, if you want to send us the keypad and control board as a unit (they are bolted together) we can determine which is the problem and repair as needed.
Best Regards,
Bruce
Posted on Oct 03, 2009
E6 F2 Fault Code on left side Display panel of Whirlpool Accubake Upper oven. There is No Cancel Button on the Display Key pad. Double oven unit has just been cutting off in middle of Bake Cycle.
this is usually a problem with the keypad, most techs would say to replace the keypad, if that doesnt solve it, the main board will need to be replaced. make sure your connectors are tight if you decide to kill power and replace the keypad
Dec 20, 2016 | Whirlpool Ovens
Rbd245pdt12 error code e6 &f2
This oven uses control board part number 8302967. E6 F2 is due to a failure in the control board. This board is no longer available from Whirlpool. It can be rebuild at www.fixyourboar.com with a 2 year warranty.
Apr 01, 2012 | Whirlpool RBD305PD Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
WHIRLPOOL GOLD DOUBLE OVEN BEEPING WILL GO BLANK THEN WILL SHOW E6 F2 TROUBLE CODE
Hi dear.Please do the following if you know what you are doing.According to your explanation,F2E6 code on whirlpool oven related with following: F2 - E6
I hope that solves your issue.Thanks.
Aug 28, 2010 | Whirlpool GBD307PDS Electric Double Oven
Rbd275pdb12 - trouble codes f2 e6 - what do these codes mean?
E6 F2 on a whirlpool double oven translates to "Cancel Key drive open". We see this frequently and is always a problem with the control board. At www.fixyourboard.com it can be repaired quickly and reliably at a fracton the cost of a new board.
Jun 03, 2010 | Whirlpool Ovens
I have a Whirlpool model RBD275PDB12. I am
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
Jun 03, 2010 | Whirlpool RBD275PD Electric Double Oven
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
729 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
