Question about Whirlpool SF368LEPS Stainless Steel Gas Kitchen Range
OVEN WILL NOT LIGHT IT SAYS IT'S ON BUT WON'T IGNITE OR COME ON
    President:
  • 1,304 Answers
More than likely its a bamke ignitor, one sure way to find out is the range will come on but never get hot and never get above starting temp
remove the bottom panels and you should be able to see the ignitor, turn on the range as normal and visually inspect to see if the ignitor glows
no glow,,,, there you go
call sears repair and tell em you need part number
9758079 ignitor bake
its about a 5 on a 1-10 difficulty ,,,,,unplug the range
Posted on Oct 03, 2009
  • Don Gross May 06, 2013
    See if the ignitor GLOWS?? This is a SPARK ignitor!!!
I melted some butter in the oven, it dripped into the burner holes and now they won't light.
i would let do this by specialist,to clean the burner.
butter can also ignite or you can get gas bubbles,not safe
Jul 26, 2012 | Stoves Ovens
Oven won't ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 05, 2011 | Whirlpool Ovens
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Wirlpool gs475lems Oven will fail to light and keep temp.
I HAVE A 2 MONTH OLD GAS RANGE AND IT APPEARS ED-F3 AND THE OVEN DOOR IS LOCKED HOW DO I GET IT TO UNLOCK
Feb 15, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Whirlpool SF368LEPS Stainless Steel Gas Kitchen Range Logo
247 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
