Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage opener only travels about 12"
Garage door opener moves about 12" to the closed position and then returns to the open direction 12". I disconnected the door - same problem. I removed cover and manually turned motor to the half open position. Same issue - door travels about 12" to the closed and then returns to the open direction 12". Same results with either wall switch or transmitter. Mdl 139.535
Thank You
    President:
  • 3,197 Answers
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Check to make sure they are properly pointed at one another. If the main light doesn't flash then it is probably the RPM sensor board which is a small printed circuit board just in front of the motor. You might also increase the down force just a bit. This is an adjustment on the rear near where all those white wires go.
Posted on Oct 03, 2009
  • 557 Answers
Sounds like something is binding causing the safety feature to activate the same as if it hit something. Bring the motor down to the point where this happens and pull the plug. At this point turn the motor manually and attempt to find the obstruction. You can also confirm this by changing the sensitivity so as to almost cancel it. Don't leave it that way, the safety feature is to protect anything it might hit as well as the opener itself. Do this only for diagnostics only and be ready to kill the power.
Posted on Oct 02, 2009
My l/m door goes down but come right back up help
This can be one of two problems ! First problem can be that their is something blocking the infrared sensors that would cause the door to go back to the up position but in most cases if their is something blocking one of the sensors the door should not even move and just make a click sound and you will see the lights flashing on the garage door opener , it can also be a mis aligned sensor not pointing directly at the recieving sensor or vice versa! Ok if that was,nt the issue then you can make shure that the door isn,t traveling further then where it needs to stop to be closed, sometimes the chain or belt depending on your opener loosens up and can add an extra inch of travel to the door causing it to return to the up position, to fix this you have 2 adjustments on your opener ...1 will be a pressure adjustment ...you can turn the adjustment to midway #6 to add some pressure so that the opener does not sense the xtra travel of the door , You can also backoff on the downtravel adjustment a turn or two and that will make the door not come down as far ...This adjustment is used to set how far the door goes up and how far you want the door to come down, you will see a picture of the door on both of these adjustments with an arrow letting you know which way to turn the screw ..remember each full turn of the screw equals 1/4" inch of travel to the door just follow the direction of the arrow or turn the screw counter clockwise for less travel !,,,Hope this helps you Sincerely Glenn
Jun 13, 2014 | liftmaster Garage Door 1/2 Hp
Liftmaster 1265 closes and then immediately opens garage door. Pulling chain release does not release chain. Only way to keep door closed is power shut-off; performing very rapid return when reaches...
There are two possibilities here. First is if the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Second is if the door is reversing when it hits the floor. This is a problem with the door traveling too far in the down direction. Locate the 'down limit' located on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
To release the door with the rope - pull straight down and then pull the rope in the direction away from the door. This should lock the mechanism in the open position. To release this pull straight down and release.
Sep 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hello, I replaced a worn out garage door motor with a new craftsman model. The door try's to travel down when the opener is pushed, even though the door is fully closed. I'm no garage door expert, but...
Yes, reread the directions travel needs to be set for both up and down, and MUCH MORE IMPORTANTLY the safety settings must be set. This allows the door to close on a foot and not cause damage....VERY IMPORTANT to set correctly....
Apr 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
No matter when i adjust the force the door goes down, stops briefely, them returns to open position. can't get force adjust to let it stay down.
If the door is hitting the floor and then reversing it is traveling too far in the down direction. Locate the 'down limit' on the side of the motor unit and turn it in the opposite direction of the arrow printed on the cover. Some tweaking of this control will be necessary to get the travel just right. The force adjustment affects the safety of your opener. Try to put it back where it was.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have Craftsman ½ HP Garage Door Opener Model 139.18458D. It reopens immediately after closing. Sometimes it works normally, and sometimes gives this problem. I have tried adjusting the close force,...
It sounds like the door is traveling too far in the down direction. When it hits the floor the safety causes it to reverse to the open position. You need to adjust the 'down limit' not the force.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage door opener is not cycling all the way closed, before returning fully opened. It is traveling about two feet down before stopping and gong back to the opened position. There is no obstruction in...
If the main lights are flashing 10 times it is a door sensor problem. If the lights are not flashing it is a bad RPM sensor board which is a small printed circuit board just in front of the motor. It can be purchased at Sears or any good door opener service company.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2HP Door Opener won't stay closed
Loosen the chain and run the opener until the sprocket runs in the counter clockwise direction and stops. Now with the door in the open position replace the chain. This will get everything back into sync but I hope you remembered where all those controls were. You need to put them back in their original positions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
145 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
