Question about Little Giant 599117 RFSN9 15' Power Cord
Sounds like power is getting to the pump motor but it is not ejecting
  • 87 Answers
Once power has been verified, look on the bottom of the pump to see if the impellar is still att, may have came apart, also mak sure the suction intake is free of debris, and or also look@ your check valve to see that it is not stuck in the down position, hope this helps
Posted on Oct 02, 2009
Sony DVP-NS50P not ejecting
hi,
You have to check the try loading belt of you dvd. if the belt is loose or broken the will not be ejected. you can see only OPEN in the display. You can simply check is it related to belt. Power on the dvd player and then press the eject button. Place you ear on the top of the player and listen is there is any humming sound (sound of motor running). If you hear the sound then the belt have some problem.if there is no sound then the problem is related to the electronic part which drives the motor. if so you have to change the mother board of you dvd player. Because the all the parts in it are smd( surface ***** device) also the availability of the part is very rare. Also you have to consult the sony authorized servicing center to repair the same.
If you here the sound then you Can rectify the problem by replacing the belt. Normally you cant see the belt from the top of the mechanism. Because it is beneath the tray. you can see it only if the tray is in eject position.
Remove the top cover of your dvd player. As it is sony dvd player you can eject the tray manually. for that watch the bottom of your dvd player. You can see a slot closed by a plastic strip just bottom of the mechanism. Pull out the plastic strip. Watch through the slot. you can see a Noach which you can move manually to the left and right. put a screwdriver in it and pull the Noach to the side. the try will get ejected. Not fully but partially. You have to pull out the tray fully manually.
If you closely look at the inner end side of the try then you cn see a motor and belt. if the belt is loose it will be in there in the motor pulley and in the wheel. if its broken broken then you have to find it where it . Take the belt as sample and bring a new one. you will get the belt at any of the electronic spare parts shop near you. Put the new belt in the position. inset the tray by pushing it in to inside slowly. power on the dvd player and the press the eject button.
ok
Apr 29, 2011 | Sony DVP-NS50P DVD Player
It makes a humming sound but does not pump water. the pump gets very hot there is no debre in the outflow
The motor is binding that's the humming noise. Check to see what **** the thing sucked up. Then try to clean it out. I dont know what happened
Dec 25, 2010 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
Pool motor makes a buzzing sound but doesn't work
sounds like it has a bad capictor .. look fr a otor shop in your area that tsts them , should be free test
May 30, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
DVD player will do nothing
Ok so I took the cover off to see if I could figure out the problem. Don't have a complete solution, but I did get somewhere. There is a silver cylindrical motor attached to the eject mechanism wheels on the VCR side. When I unplugged the tape from the back of the little motor, the progressive light goes out and the sound from the motor stops. When I manually turn the wheel/arm attached to the motor, the other wheels/gears turn and I can manually eject the tape. Also when I get to a certain point, my progressive light starts flashing like yours was. Anyway it all seems to be related to the little motor. I figure if you replace that, it would work. At least that is what I might try, I'll keep you posted.
Aug 27, 2008 | Sony SLV-D300P DVD Player/VCR
Eject Error
Does your camera make a buzzing sound as if it trying to eject? Or if you listen carefully can you hear the very faint sound of a motor free-spinning? I have just repaired a friends camera of a very similar model to yours with the same problem. There is a tiny motor in the tape compartment which comes loose from its "pathetic" mounting. This causes the gears to disengage and in turn renders the eject mechanism useless. The motor is in the bottom left hand corner (looking in as if loading a tape) right underneath the Player, off, camera selector. The motor simply needs to be repositioned to engage the gears. I then added some glue to stop it happening again (be extremely careful though as ANY overspill of glue will ruin the camera completely).
Aug 15, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
B&O DVD1 PLAYER DOES NOT OPEN ON DEPRESSING EJECT. NO DVD IN IN THE PLAYER. CONNECTED TO B&O BEOVISION. HAVE TRIED DISCONNECTING POWER. ANY SUGGESTIONS?
if disconnecting power does not help then you will have to open the player and make the DVD tray roll out.
Aug 05, 2008 | Televison & Video
Flashing code C:32:11
Remove the battery. Re-attach the battery, and power up the camera. Should retutrn to normal.
Jun 03, 2008 | Sony Handycam DCR-TRV140E Digital...
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Little Giant 599117 RFSN9 15' Power Cord Logo
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
