Hard drive and cd drive not recognized
My laptop wont recognize either the hard drive nor the cd drive. i want to install the OS and boot from cd drive but wont allow me.
is the motherboard fried. should i replace the motherboard?
at times the computer reads the hard drive and cd drive. other times it wont read either....
  • 154 Answers
In this case if your laptop runs occasionally sometimes not. The prom the is the faulty cable which is connected to the HDD and CD drive. Try to replace the connector cable with the other one. Check also the BIOS setting of the HDD and CD drive.
Regards
nicole
Posted on Oct 02, 2009
Installing Operating System on New Blank Hard Drive
Did you partition the hard drive ? Make sure that it is compatible .Some HP computers will only allow you to use certain products and you can not upgrade\downgrade or change an operating system .Try going online on another computer and see if the devices in your netbook can be changed or upgraded. HP is big for "Thank you for your business & your stuck with it the way it is " I wish you luck .
Feb 06, 2014 | Intel Hp Mini 1000/1035...
I installed a new internal hard drive in my Inspiron 1750 laptop. I am getting a No boot sector on internal hard drive error. How do I get it to boot up and get recognized?
Have you installed the Windows OS on the new HDD? Insert the new Windows OS in the DVD rom drive, shut down, Unplug, remove battery, plug in, at boot the new OS DVD should start and ask Press any key to boot from CD/DVD, tap key.
Feb 03, 2013 | Dell Inspiron 1750 Laptop
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
When i start it say Reboot and select proper boot device or intsert boot media in selected boot device
Most probably the cause is one of the following:
  • No OS installed.
  • Hard-drive connection is loose.
  • Windows is corrupt.
  • Harddrive jumper is not figured correctly (in case of IDE PATA) or it may have malfunctioned.
Disconnect the PC from the mains supply, remove the cover on the system and check for any loose cable connections of hard drive.
Check inside the BIOS whether the drive is listed and as the first boot device in Boot Order tab.
Note: During inspection take care to avoid touching any board component unnecessarily. Also avoid using force.
Dec 17, 2009 | Intel D845GVFN Motherboard
Boot problem
open your bios setup and check the cd rom is recognized and check the boot priority is set to allow to boot from the cd rom first.
Feb 20, 2009 | Dell Computers & Internet
My Motherboard wont recognize my Hard Drive
Is it Sata or IDE?.Also is your boot order set to the CD rom as the first device.The O.S is bootable only if the CD runs it first. Windows should format it later in the install process.
Nov 25, 2008 | Computers & Internet
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Please help... i am installing a new sata hard drive but it is not detected...
Please give us more information.
1. How old is your PC?
2. Size of your old & new hard drive.
3. CPU speed, motherboard brand & model.
If your motherboard unable to recognize the size of the new drive. then, you can find BIOS update for you motherboard.
Mar 18, 2008 | Intel Motherboard
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
