Question about Whirlpool LER4634J Electric Dryer
Dryer stopped working
Dryer is making clicking noise as if its trying to count down but won't dry or turn on the inside.
  • Whirlpool Master
  • 7,482 Answers
The clicking noise is probably the timer switch working ok...no problem there
Sounds like you could have a broken belt, that will keep your drum from turning.
If you have a front load machine, remove the front, that will expose the drum. You should see the belt on the drum, if it is not there then it is broken.
You would then remove the drum and replace the belt, while your at it you should go ahead and lube the drum rollers at the shaft with a good grade of machine oil...Like 3 in One oil...it will extend the life of the rollers and help to keep them from making noises later.
I hope this helps
Posted on Oct 03, 2009
I have a gas dryer. It heats up just fine, but it won't shut off. if put on time dry it won't count down the time and on any other cycle it will just keep running and drying
Oh I can't think of the name of it right now but the whole knob assembly inside needs to be replaced. It's like a timer its integrated into the knob.
Jan 05, 2015 | Dryers
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
Whirlpool LER4634J Electric Dryer Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
