Question about Dell Inspiron 2200 Notebook
How do you replace a dell inspiron 2200 laptop keyboard?
  • 154 Answers
Order item number J617 from Dell computers. It will arrive with everything you need except the small Philip screwdriver. The package will contain the instruction manual, plastic scribe and of course the new keyboard.
  1. First, lay laptop flat, turn the laptop off, disconnect power source and remove the battery. Then, lay the laptop flat (180º) on the table or desk where you plan to change the keyboard.
  2. Insert scribe and pop up the hinge cover. Using the plastic scribe, gently insert under the hinge cover’s corner and lift the hinge cover off of the laptop. Be gentle. May require a little wiggling to ensure the little connectors pop out of their location.
  3. Remove hinge cover, Once the hinge cover is removed, lay it to the side.
  4. Locate the two small M2.5 x 5mm screws that attach the keyboard to the laptop and use the small Phillips screwdriver to remove them. There is at least one on each side of the laptop. They were hidden by the hinge cover and should be visible once that cover is removed.
  5. Use the plastic scribe, insert under keyboard and gently lift. Little nodules on the end of the key board and a keyboard cable in the center secure the keyboard to the laptop. Gently wiggle the keyboard until it is loose.
  6. Pull up on the keyboard cable until it pops loose. Set the bad keyboard to the side.
  7. Take the new keyboard and insert the cable into the cable slot on the laptop. Press the cable lift down on top of the cable and secure it. (It is imperative that you get this part right otherwise, the keyboard will not work when you put it back together!).
  8. Insert the nodules on the end of the keyboard in their respective slots and replace the two M2.5 x 5mm screws.
  9. Replace the Hinge Cover.
  10. Turn the laptop on and – VOILA! You are back in business. The troubleshooting in replacing keyboard is done.
Regards
nicoleFIXIT
Posted on Oct 02, 2009
    President:
  • 2,600 Answers
5 Suggested Answers
suffolkpo
  • 6 Answers
SOURCE: keyboard space bar
only two possibilities, first is the rocker springs at each end or the bar are causingit to not make contact. or the bubble switches under the keyboard. I had a similar problem on an inspiron 6400 and I had to VERY CAREFULLY remove the keyboard,then the button to reach the bubble switch which had lost the plastic bushing that covered the shorting contact, good luck given the insane price that dell wanted for a new keyboard fixing it myself was the option.
Posted on Jan 04, 2008
ginko
  • 19396 Answers
SOURCE: replacing dell 2200 keyboard
Here is the documentation for dell inspiron 2200. You should refer to the service manual. In any case be aware that changing a laptop keyboard generally is not an easy operation for a beginner.
cheers
Posted on Feb 16, 2008
  • 72 Answers
SOURCE: Dell Inspiron 2200 loose DC power pin connector
Not that hard to do the repairs yourself.....The pin assembly is usually available on the web for $ 10-$20. Take your time taking the unit apart, take notes on the dis-assembly so when you go to re-assemble the unit you know what goes where. Once you get it fixed you might think about getting a cable retention device to keep the problem from re-occurring.
Posted on Mar 12, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
How to remove the battery of inspiron 2200
1. Turn your Dell 2200 laptop over.
2. Find the laptop battery release button lock for your Dell 2200 laptop.
3. Now that your Dell 2200 laptop battery is unlocked, find the battery release button down.
4. Holding the laptop battery release button, gently pull your battery away from the laptop.
5. Now that your Dell 2200 battery is removed, grab your replacement Dell 2200 battery for installation.
6. Insert the battery into the slot. Push the Dell 2200 battery towards the laptop and secure it in place.
Jul 04, 2016 | Dell Computers & Internet
My dell inspiron 2200 isn't recognizing parts of the keyboard, like the enter key
If some of your keys are working and some are not working, then most probably, your keyboard is broken, try to clean it properly and if it doesn't worked out please send it to nearby service center
Sep 19, 2010 | Dell Inspiron 2200 Notebook
The letters ZXCV does not show on monitor nor write to document. please can you help? dell inspiron 2200.
Reseat the Keyboard ,Dont try Yourself call Dell & be on the call so they will walk you through
Jan 09, 2010 | Dell Inspiron 2200 Notebook
Monitor comes on very dim, I can't see
click your "fn" key and then press the brightness key on the keyboard (it will be a blue or green "sun")
If this does not work, plug an external monitor to the laptop, if the screen is good on the monitor, your LCD display panel is shot.
Mar 21, 2009 | Dell Inspiron 2200 Notebook
My keyboard and mouse do not work
Basically, get yourself a wireless keyboard and mouse combo. Plug in the USB dongle or whatever it comes with and install the software off the cd it comes with. You'll be in business in like 10 minutes.
I recomment Microsoft Laser desktop or anything by Logitech.
Jan 20, 2009 | Dell Inspiron 2200 Notebook
Brightness for Dell inspiron 2200
install keyboard drivers first and try...
Jan 17, 2009 | Dell Inspiron 2200 Notebook
Change keyboard letters
Keyboard replacement instructions: http://support.euro.dell.com/support/edocs/systems/ins2200/en/SM/keyboard.htm#1084976
Dec 17, 2008 | Dell Inspiron 2200 Notebook
Replacing dell 2200 keyboard
cheers
Feb 16, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
375 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
