Question about Casio Exilim EX-S600 Digital Camera
Lense stuck outside and won't withdraw
Lense stuck ,
    President:
  • 1,197 Answers
If ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Oct 20, 2009
Sony DVP-NC685V wont turn on
Hi
Check your power source first and establish its in order.
Then you may try and replace the power cable.
Hope it helps.Thanks
Feb 19, 2012 | Finance
Tip
Know Your CD Grace Period!
When investing money in a CD, make sure you know your grace period and mark it on your calendar. Your grace period is when you can withdraw money from the CD account, and it usually lasts anywhere from 7-10 days. Because banks tend to automatically renew at the current rate, you may be stuck with lower interest rates when your CD matures if you do miss it. <br>If you do choose to withdraw money outside of your grace period, some banks may charge up to a $25 fee. And no matter what the original fee was, the longer term the CD, the higher the penalty.
on Aug 26, 2013 | Finance
Nikkor 55-200 stuck
You could take it apart, but would you be able to put it back together? Do you have a lens collimator and other gear needed to ensure proper alignment? If you don't have the proper tools, leave the job to a trained professional (or replace the lens).
Nov 18, 2011 | Cameras
Outside gas door will not release from inside
Gas cover has a pressure clip that fits inside on the gas door latch. When you pull on the cable in the cabin a little arm withdraws and the pressure clip causes the gas door to spring open. If the clip is missing, the arm withdraws but there is no spring to pop the gas door open. Replace the pressure clip.
Mar 14, 2010 | 1998 Toyota Camry
I have the same problem
Hi:
If you did not drop it, you probably have some dust or small particles around the outside of the lense. They prevent the lense from fully opening. The lense cover might have the same problem. As a result it is stuck.
When the lense open up try to clean around the lenseor the cover. If it opens, but not all the way out, try to pull it out NOT too hard.
When it opens, try dust off. Make sure you do not force too hard on all of the steps above.
Good LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 23, 2009 | Samsung Digimax S630 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Protective lense shutter is stuck partially closed, causing black corners in the photos. How do I fix this, or remove the shutter completely?
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A610, you might want to extend your zoom all the way out before removing the camera's batteries. Note that the A610 has four shutter leaves instead of two, so pay particular attention how they're assembled if you remove the lens ring. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures. One other thing, try not to get any alcohol on the lens itself:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Good luck, and remember to do this only as a very last resort (try the other listed procedures first). Oh, and if you do decide to try the repair, please post how it went.
May 28, 2009 | Canon PowerShot A610 Digital Camera
CAMRA
you have jammed the 3 lens studs outside of the track , you cannot fix it without dissembling the entire camera to the lens,
its best to leave it alone and sell it on ebay for the lcd is worth 35 to 60
Apr 13, 2008 | Cameras
Casio Exilim EX-S600 Digital Camera Logo
180 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
