Samsung ML-2240 Laser Printer Logo
Posted on Oct 02, 2009
Cant print thermister open, cycle power cant print heellllllllllp
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
My tumble dryer is completing cycle but heaters are not working and cloths are not drying. There are two thermister or sensor on drum. One of them is not showing continuity. Is it possible we can get
Almost every dryer i have seen repaired with heating issues has been due to element failure. Thermisters are cheap. Change them if you suspect. I have found meLted elements. Some very small but had to remove the element to inspect. to find the problem. even if open partially it will never heat up properly.
Feb 04, 2015 • Dryers
50.1fuser erro hp5550dn
50.1 Fuser error:Low/No Fuser tempatrature, replace Fuser assembly.
For service engineers: Reason: thermo switch open, remove fuser assembly, dis-assemble up sleeve, check switch continuity, if no continuity, remove switch & just hit gently on aluminum capsule till continuity comes,make sure it should not damage or dent,once continuity comes, clean main thermister & sub thermister, fix it back, power on the printer, chek errors,adjust fuser temperature in low, give prints up to 50 blank copies, chk.. if problem repeated replace Fuser assembly, but success rate is 70% for above exercise. Note: Only professionals can perform this activity..
Thermo switch:
My lg wm1832cw washer was in spinmode when it made a bam noise and lost power. I had to change the board ans when I did the upside down f and e came on. I changed the thermistor but am still getting the...
check the wire harness from main board to thermister. tE error code is either an open or shorted thermister. If you replaced the main board and thermister, the only other option you have is a bad harness. Reseat connectors on the main board and all along the harness to the thermister
LQ 300 +2 auto pause during printing
This is a feature provided by the manufacture to protect the print head overheat for small dot matrix printers. Here giving printer head connection diagram, the last two row have temperature sensing (thermister) connection pin 1 to 1. If the thermister is faulty in the print head the printer will auto pause abnormally. Check the printer with compatible / EPSON recommended print head. These kind of small printer only for POS printing not for continues printing. 2_17_2012_8_31_04_am.jpg
2helpful
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
GENE
1helpful
My sp1000sf aficio printer is showing me fuser temp error dont no why? Cant print
oh its a big problem.fusing temperature error means that either the thermostat or thermister is open in fuser unit. only a Ricoh technician can check it and tell you as it requires a lot of stripping to take fuser unit out and test the thermostat. there is no reset procedure for it mate.
2helpful
Led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
23helpful
5answers
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Uaable to reach the correct tempature
Your rinse Thermister is shot. Replace the thermister between the fill valve and the solenoid. Also be watchful of the 120V, ensure this is secured as there is two power sources. Is ya good
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
