Question about Polaroid FLM-323B Television
Doesn't seem to get any power to it, don't even get the led light. Last year replaced the caps I know it isn't that problem what else should I look at.
    President:
  • Polaroid Master
  • 1,779 Answers
Check to see if you have 5 volts going to the main board. If you do then check the power supply for a high on the PO connector form the main board, if that reacts then the power supply is bad.
Posted on Oct 02, 2009
Testimonial: "Though it made little sense to me, it made sense. I fixed caps a year ago, I think I can do this, scratch that I know I can do this. Thank you"
GS550 Electrical Problems.
try carefully shorting a screw driver accross solenoid the two big nuts with ignition on . try a meter on continuity starter casing to earth
Jul 18, 2013 | 1980 Suzuki Gs 550 L
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
Third brake light
I don't know what your question is but I am going to assume the 3rd brake light isn't working. This is an LED assembly which can't be serviced and must be replaced if not working. Before you do that, using a test light, and the brake pedal depressed, check for power and ground to the lamp, if there is power and ground it must be replaced. You can get one from a junkyard or ebay or your local GM parts store.
Aug 10, 2012 | 2000 Chevrolet Blazer
Plasma will not turn on,no led light
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_31_2012_5_17_56_pm.jpg5_31_2012_5_18_38_pm.jpg
May 30, 2012 | Televison & Video
Hi , I bought a 07 golf tdi last year , engine management light came on within month , the garage kept saying it is just a sensor and nothing too worry about , had a full service in dec and it came back on...
First of all you need to find a new garage that isn't just telling you what they don't know. If it were just a filter they would have replaced it and watched you drive away with a smile on your face. There is nothing better than a happy customer. The other thing is that you don't mention if the ****** is a manual or automatic. The ****** could be a bunch of different problems depending on type of ******. Also Volkswagen's are noted for many sensor problems. There are many sensors that can throw a code if they even malfunction for a second. Wish I could help more, but the information is to vague.
Apr 25, 2012 | 2005 Volkswagen Golf
The radiator and cap just replaced, tune up and oil change current. 1999 jeep cherokee 2.5L 4 cyc engine losses power after this last servicing. i use o'reilly octane booster and so far this seems to...
You don't really have a mechanic that has much knowledge
Without the vehicle to test drive & do some testing on it,
there is no way to just guess & I suspect you wouldn't
understand any of our suggestion anyway.
Find the best established shop,one that has been in the same
family for 20 or 30 years
You have to go on a road test with these people before you
leave a vehicle. Be part of the solution,go to the shop on a
supprise visit & as a lot of questions,walk into the service bay
If that isn't some they want you doing take your vehicle &
go elsewhere.
So what test tools they have,study obd2 on internet & have some
trick questions ready to fire off.
Jul 12, 2011 | Jeep Cherokee Cars & Trucks
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Polaroid FLM-323B Television Logo
353 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
