Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Select button wont work
The obnly reason that i think it would be for it to bew not working is because its old, i mean like 2 years
  • Sony Master
  • 441 Answers
Underneath the buttons you press, there is a strip with small buttons. When you press the switches on top, they press the switches underneath. The strip underneath may need to be cleaned or replaced.
CLICK HERE TO SEE HOW TO OPEN PSP SLIM
Click Here for PSP 2001 Internal Strip for Select Button
Posted on Oct 03, 2009
  • 344 Answers
The control chip under the button isnt making contact with the plastic button,, easy fix, take the cover off the psp clean the buttons with a pencil eraser and put the cover back on (without screwing it down) check for contact,,,,if it works then screw it back together if it doesnt then pop the cover off and put a small piece of tape on the select button its self to make up for the slack). Hope this helps you out..it worked for me!
What is the code for a universal remote for a seiki blu ray player
if you go into the menu on the player your should be able to find a list of codes by brand name, if it is now listed then the remote wont control that particular piece of equipment , depending on how old it is , I have experienced this before any electronic equipment more then 10 years old wont work with universal remotes , although you might also find in the instructions a way of going through all the codes search manually by pressing 2 buttons at the same time.. "example, for Directv remotes , you would push the power and select buttons at the same time.
Aug 08, 2014 | Televison & Video
Getting updates for my year old iphone.
try this:
Click here or go to this website: http://www.felixbruns.de/iPod/firmware/
you will see there 2 selections: (1) iPod; and (2) iPhone / iPod touch.
Focus on iPhone / iPod touch and select iPhone 3G (3.1.2/7D11) or iPhone 3G S (3.1.2/7D11) - depending on whether your device is a 3G or a 3G S - and then click download. Tip: it's better if you save it on your desktop.
After the download is finished, open iTunes from your computer, and select your device. You should see the restore button there but before you click it, you must first, hold Alt (or Option) if your using a Mac, or CTRL if your using Windows, once your already holding the appropriate buttons, click restore. This will let you choose what software version you want to restore in your iPhone. So, you must select the one that you just downloaded and click restore.
Now, let me just tell you that "baking up" actually means, creating a back up. It doesn't mean that your iPhone is refusing or moving back. So when you think your iPhone is stuck, just wait a little longer, I mean, do other stuff first and return to your iPhone after 5 or more minutes. Alight...
That should do the trick. Goodluck..
Feb 09, 2010 | Apple iPhone Smartphone
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
Doesnt even load the home screen
there could be 2 reasons.......first the fan might not be working and you need to buy a new one or fix what you allready have.
second it might bew dirty from the back take a swiper an clean it for 30 sec one of those will work 100%
Jun 23, 2009 | Sony Playstation 3 (PS3) Console
IPOD NANO WON'T TURN ON
Have you tried the old 'turn on whilst holding the centre button on', keep olding the button until the Apple symbol comes on?
Sep 19, 2008 | Apple iPod nano
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Spray not working.I fear it's clogged.
The pump is faulty and the selector is to select amount of steam coming out from the sole plate.I, suggest you send to your nearest repair centre.
Regards
alan
Nov 25, 2007 | Rowenta Powerglide DE011 Iron with Auto...
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
262 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
