I bought a used furnace and when i hooked it all up the green light that says working is flashing instead of staying on constantly. dont know if that is good or bad. but the automatic pilot will not light and i am not getting the fan to turn on or anything. the draft induce motor is warm to the touch after a few minutes so i know that it is trying to work. not sure if that is the correct name of the motor exactly.
    President:
  • 1,714 Answers
Something is not right here. Turn it off and check the power connections to the unit.. something is hooked up incorrectly. If you can send me a photo of the schematic I can tell you how it should be connected.
Posted on Oct 03, 2009
Hook ignition wire
This is a typical 5 wire setup. The colors can change depending on the person installing the system, meaning if the installer liked using BLUE for cooling instead of YELLOW, that's how he hooked them up. If YELLOW wasn't available, they could of used BLUE or BLACK, and visa-versa. But, the wiring below is the most common. If you have a heat pump system, it will be slightly different. Hope this helps!
R- Red- Power 24v
G- Green- Fan
W- White- Heat
Y- Yellow- Cooling
C- Blue- Common
Dec 07, 2013 | Coleman Heating & Cooling
Coleman furnace dgaa077bdta
Four flashes is limit circuit open .
May 02, 2017 | Heating & Cooling
On power up the green light is on for 2 sec.
problem with the main board inside of the DS Lite. Its not staying on with the voltage being provided. To verify this. Plug your DS Lite into a working outlet and see if it stays on.
If it doesn't stay on then take the battery out and only hook up the ac adapter to it and see if it stays on.
At that point if it doesn't stay on, try to use another AC Adapter to see if it stays on, if it doesn't then you know for sure the main board is bad and you would need to get a new ds lite.
Jan 01, 2010 | Nintendo DS Lite Console
The Pilot on my electric furnace will not stay lit, blowing cold air instead of warm. The model is L8T-UH.
Is this a code for us to come over cause electric furnaces dont use a pilot light ha! Ha! (they uses electric heat strips for heat .....but if you want to give away money..........)
Dec 09, 2009 | Coleman Mach 15 Air Conditioner
Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Mar 29, 2009 | Honeywell Programmable Thermostat Heater
Wireless mouse not working
Try to replace the batteries in it. It may be acting strange due to low batteries. If this does not help you try testing out on another system and post results.
Mar 26, 2009 | Computers & Internet
Furnace integrated control module
The light is supposed to be on, if there is a fault in the furnace the light will begin to give u a flash pattern... ie; three flashes...or two flashes.. on the furnace exterior or on one of the doors there should be a fault code chart.... read the chart on the unit it will tell you what light is on and when..
Jan 14, 2009 | Goodman GMS90703BXA Heater
Little manual does not indicate to charge unit before using
Hi-the light stays Green when it is fully charged-does not flash-just stays on!
Dec 01, 2008 | Mercury Electronics MP250 (128 MB) MP3...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
