My WS-65511 has blue bands across the top and
My WS-65511 Mitsubishi big screen tv has blue bands across the top and bottom of the screen, also has a very narrow blue band through the middle (bout an inch or less) Was told this is probably the Convrg IC but all the Pico fuses HAVE continuity. What else could be causing this problem?
    President:
  • 1,884 Answers
Pico fuses have nothing to do with the ICs except for allowing the current tot flow through them if it is equal to or less than the required voltage. The ICs are the small modules inside the box that actually handle the picture and sound modules of the TV. The display IC could be faulty and needs repair/replacement. Or if the TV is old then the picture tube may be aging.
Posted on Oct 02, 2009
I have and 65" Mitsubishy HDTV model WS-65511 serial :118393 I never had a problem before but las week i was watching a program and sudenly a second blue image was on the scrren, i decided to open the...
there just might be a slight chance an adjustment of g2 high voltage to the blue tube might help however there is a good chance there is a problem with the tube
Oct 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Reset Mitsubishi WS-65511 VChip Password
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi WS-65511 Front Lock
Mitsubishi WS-65511 Manual Download
on May 03, 2010 | Televison & Video
Tip
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Glare-can we remove plasting sheeting on screen?
yes, you need a philips screwdriver, pull the speaker grill off, remove the 4 or 5 screws along the bottom of the screen assembly, unlock the 2 electrical plugs and remove them from their ties, lift up on the screen assembly and remove it. turn it upside down and remove the 4 screws holding the bottom of the frame on, remove frame bottom, slide screen protector out, re-assemble, bingo, no glare.
Sep 08, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Problem with picture
my tv got blue line acroos screen and a yeloow shade on top of screen What can i do
Nov 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
