Question about Toshiba Satellite 1715XCDS (  K000882440) Motherboard
How to connect to internet using LAN
I have a Toshiba Satellite 1715xcds, and i want to connect it to the enternet thought my gateway that is connected to a modem. the modem is connected to a router. I want to connect to that router though a Netgear wall plug ethernet adapter. In my laptop I have a Lan card, but thats about all I know. I don't know About drivers or anything. I've allready turned off the setting to automatically connect to dial-up, i just got stuck after that point. Please help with step by step instructions. thank you, matt
also i just tried connecting though an ethernet cable and opening internet explorer, and it just sits there and thinks and at the bottum says "Detecting Proxy Settings"
  • 28 Answers
Check that you have entered DNS Server Ip and Router IP address as your default Gateway in network card ip settings...
run command:--Start-->Run--->Type.....Cmd
Enter----Type...Ipconfig/all---will show you ip details
Check Router Config(if uoi manage)that NAT Proxy configured on that.....
Posted on Oct 03, 2009
How do you set up a LAN connections on a toshiba satellite 1715xcds It has a LAN card, but i dont know how to format the computer to run only on LAN. It still wants to use dialup
If you referring to the message when you open up internet explorer. You need to go to the setting of your browser and go to connections. Select never dial a connection. If this message is from a program. Have it disabled first.
Oct 02, 2009 | Toshiba Satellite 1715XCDS...
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
Lan connection not working on Toshiba satellite laptop
Try setting up a new Broadband internet connection. Input all the appropriate Login info and you ought to be good to go via the LAN port. Everything else is aimed towards Wireless.
Sep 19, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
My Toshiva sound drive is gone, now no Audio,pls help me out. u can get to through ghalirogo@yahoo.com or +2348023702045. best regard, Ghali S.Rogo
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-1715XCDS/download/page,sh,30795,221,19,.html
go here for your drivers
Sergio
Mar 26, 2009 | Toshiba Satellite 1715XCDS Cooling Fan...
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Lan driver
A simple Google search resulted in this page (amongst others):
Otherwise find out what LAN card you have installed and search the Internet using Google and this string:
(Brand name) (model number) +driver
and you should find the driver that you are looking for.
To identify your LAN card:
RIGHT click on My Computer and select Device Manager. Your Lan card should be listed there.
Good Luck.
Apr 08, 2008 | Toshiba Satellite 1715XCDS Notebook
Windows NT 4.0 Workstation Drivers?
you need to use windows 2k drivers with windows 2k cant use them on nt
go to battery plus for battery
Feb 21, 2008 | Toshiba Satellite 1715XCDS Notebook
Wireless lan
check ur gateway setting and also check that the access point or router is conneced to internet or it is down.
Sep 19, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba Satellite 1715XCDS (  K000882440) Motherboard Logo
285 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
