Vizio Sound Problems when using HDMI
I just bought a Vizio 47'' LCD HDTV (Model SV470M). This TV is connected to my cbale Box (Motorola DCX3400) using HDMI cables.
Occassionally, when I change channels on my cable box, the sound on my Vizio tv completely drops out. No problems occur when I use Component cables, only with HDMI cables.
Any clues on why the sound on my Vizio Tv occassionally drops out?
  • 192 Answers
SOURCE: Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
Posted on Dec 22, 2008
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
  • 586 Answers
SOURCE: no picture but only sound
If you are expert and have experience then follow the instruction given below:
Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
And if you are not a tech person then i advise you to please contact any expert nearby, this problem bit technical.
Hope this will solve the problem.
Thanks for using fixya.
Posted on Jul 24, 2009
  • 8457 Answers
SOURCE: We just bought a vizio LCD and have it connected
Reset all audio setting to factory setting.Unplug,replug u should get sound back,if not problem with ur backlight video board.
Posted on Dec 23, 2009
SOURCE: cable box is working, TV has black screen and no
cable signal is weak. Tech. must check house wiring.
Posted on Jan 13, 2010
When I change channels, some times, the sound goes off. The sound comes back only after switching the cable box off, then on again. Is there a solution?
power off all units then redo all connections especially if it is HDMI they can be just a little lose and cause the sound to drop out
May 17, 2015 | Vizio SV470M LCD TV
Where can i get a new screen for my 47"vizio hdtv
Ouch, will most likely cost as much as a new set. You can try Shopjimmy.com, retechtv.com, or EBay.com
Jan 17, 2013 | Vizio Recertified - 47" Class 46.96" Diag....
I have vizio sv470m and all of the 4 hdmi plugs stopped working one at a time.
Power doesn't have to be knocked out for a cable box to destroy the HDMI ports on a TV. Thunder miles away will put voltage spikes on the cable system which in turn trashes the main board in the TV. You can get parts for your TV here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 30, 2018 | Vizio VO47L 47 in. LCD TV
Vizio sv470m
Try unplugging all units involved for a while--make the HDMI connection when they are disconnected from power--HDMI does not like being hooked up to units that are powered and or on.
Jun 14, 2012 | Vizio SV470M LCD TV
47" vizio has sound no
Have you selected the proper input for how you have it configured? If using an HD connection, select the HDMI 1 input. If you are using the coaxial cable connection, then select TV input. If you are using the three RCA inputs (yellow, red, white) then select AV input.
Mar 01, 2011 | Vizio VO47L 47 in. LCD TV
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Sep 24, 2009 | Vizio SV470XVT 47 in. LCD TV
Televison & Video Logo
472 people viewed this question
Top Televison & Video Experts
