Question about JAHT Technologies Corp. JS-2008EP 8x10/100 Mbps Networking Switch
Setting for AP via Router Mikrotik
Please help me about setting Router Mikrotik for AP JAHT
  • 51 Answers
Please connect a one end of the cable named v.35 in the consloe port of router and other end in the modem.load the router through console port through roughter cd...
thank you...
Posted on Jan 05, 2008
I Have Mikrotik RB 1200 After Add Filter For Firewall Then Now I Can Not Access And Reset And Hard Reset What Can I do ??
Use winbox. Connect Pc/Laptop directly to ethernet port. Connect via the MAC address (it's printed on the underside usually). Otherwise you'll have to physically factory reset it.
Dec 23, 2015 | MikroTik RB1200 - RouterBOARD , 1U...
No pin in setting up
pins r used to setup WPS login - not recommended
log into router via wired connection and disable WPS then setup wireless password.
Dec 10, 2013 | Edimax 4 Port Wireless AP Broadband Router...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Encore WIRELESS LAN EXTENDER
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Connection - Zoom Wireless-G AP+4, model 4401
Cathy I have the same make and model maybe I can help. I speak both Tech and Non Tech so stop me if I lose you.
1. Did you go through the set up process of first connecting to your wireless router through the cable provide via your PC/Laptop?
2. Congfiguring your wirless via your browser http://10.0.0.200 ?
Sep 14, 2008 | Zoom (56600000) Router
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
JAHT Technologies Corp. JS-2008EP 8x10/100 Mbps Networking Switch Logo
540 people viewed this question
Top JAHT Technologies Corp. Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a JAHT Technologies Corp. Computer and Internet Expert? Answer questions, earn points and help others
