Question about Skil HD5825 6-1/2" Worm Drive saw
How to get blade off - Skil HD5825 6-1/2" Worm Drive saw
    Problem Solver:
  • 6 Answers
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the right side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For a worm drive saw with the blade to the left of the motor, the bolt should have left hand threads (non-standard) which means you loosen the bolt by turning it clock-wise.
Posted on Oct 03, 2009
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 | Bosch Saws
Where to buy replacement fan blades
everywhere Christine!
  • replacement fan blades ' eBay www.ebay.ca > Search > replacement fan blades Find great deals on eBay for replacement fan blades and replacement ceiling fan blades. Shop with confidence.
  • Replacement Fan Blades - Plastic & Aluminum Fan Blades ... https://www.grainger.com/category/fan-blades-and-propellers/hvac... Keep air circulating with replacement fan blades and propellers from Grainger. Get what you need to renew or repair broken fans, condensers and air circulators.
  • Amazon.com: replacement fan blades: Tools & Home Improvement www.amazon.com > Search > replacement fan blades Online shopping from a great selection at Tools & Home Improvement Store.
  • Fan Blades & Arms - Ceiling Fan Accessories - Ceiling Fans ... www.homedepot.com > ... > Ceiling Fan Accessories Shop our selection of Fan Blades & Arms in the Lighting & Ceiling Fans Department at The Home Depot.
  • Aluminum Fan Blades - GlobalIndustrial.com www.globalindustrial.com > HVAC/R & Fans Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Aluminum Fan Blades - www.globalindustrial.ca www.globalindustrial.ca/c/hvac/parts/fan-blades Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Replacement Fan Blades - MSCDirect.com www.mscdirect.com > ... > Fans > Fan Accessories & Replacement Blades Discover Fan Accessories & Replacement Blades and other Fans at MSC Industrial Supply. Over 1 million products that ship and deliver fast.
  • ceiling fan blades ' eBay www.ebay.ca > Search > ceiling fan blades Find great deals on eBay for ceiling fan blades and ceiling fan replacement blades. Shop with confidence.
  • Ceiling Fan Blades Replacement - Price Comparison - Canada www.shopbot.ca/ceiling-fan-blades-replacement/price/canada/593664 Ceiling Fan Blades Replacement - Find the Lowest Prices in Canada. Shop Smart with Reviews, Advice and Prices. Shopbot is Canada's Favorite Price Comparison Site!
  • Ceiling Fan Blades ' Replacement Fan Blades ' ATG Stores www.atgstores.com > ... > Fans > Ceiling Fan Parts & Accessories Shop ceiling fan blades & replacement fan blades at ATGStores.com, a Lowe's store. We carry top brands including Monte Carlo, Hunter Fan, & Fanimation.
  • Feb 18, 2016 | Dryers
    How to install blades
    Almost all scroll saws use a 5 inch blade. You need to take all the tension off your saw before installing the blade. Make sure you are using the right kind of blade. Either it is a pinned blade or non pinned blade. Some saws can use either. Make sure the teeth on the blade is facing down toward your saw table. Clamp the blade into the blade clamps and then add the tension. You should be ready to go now
    Jul 12, 2014 | Saws
    How to put together the blade
    askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
    Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
    This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
    Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
    Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
    Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
    Turn blade over like this while still holding the blade together askmanny_11.jpg
    Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
    the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
    We hope this was helpful when assembling a clipper blade.
    May 11, 2011 | Andis AG 2 Hair Trimmer
    Sabre saw- craftsman - 17256 - change blades
    This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
    You can use with both 'T' & 'U' shanked blades.
    Feel free to ask me any other questions about this saw.
    Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
    Took blades off to clean and oil unit and can't get the unit back together.
    First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
    Mar 21, 2010 | Oster 76974-160 Hair Trimmer
    Dont know how to install blade
    on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
    Oct 07, 2009 | Andis 01690 Hair Trimmer
    How to change the saw blade
    Adjustments
    LARGEHEXWRENCH
    TO REPLACeTHE BLADE
    See Figures 43 - 45.
     Unplug the saw.
     Lower the saw blade, raise the blade guard, and remove the throat plate.
     Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
     Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
     Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
    Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
    To replace the blade with an accessory blade, follow the instructions provided with the accessory.
    To install a standard blade:
     Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
     Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
    SMALLHEXWRENCH
    Fig. 43
    Blade
    Bladewasher
    arbor shaft
    Bladenut
    Fig. 44
    BLADEGUARD
    THROATPLATE
    spreader
    BLADE
    Fig. 4535
    ADJUSTMENTS
     Rotate the blade by hand to make sure it turns freely.
     Lower the saw blade and reinstall the throat plate.
    NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
    Sep 18, 2009 | Saws
    How to fit bosch PHO 15-82 planer blades
    1. Unplug from mains and turn planer upside down.
    2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
    3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
    4. Rake any dirt out of the blade track with screwdriver blade.
    5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
    6. Repeat with second blade.
    7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
    8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
    Pictures below from Bosch manual for further information
    Sep 16, 2009 | Bosch Tools & Hardware - Others
    Blade type
    blades are available for different applications. A few common blades include:Steel Blades are inexpensive and work well for cutting softwood. Steel blades dull quickly in hardwood. High-Speed Steel Blades are harder than steel blades and stay sharp longer. Carbide-Tipped Blades are more expensive than other blades, but they stay sharp much longer than steel or high-speed steel.
    Aug 27, 2008 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
    Skil HD5825 6-1/2" Worm Drive saw Logo
    114 people viewed this question
    Top Skil Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you a Skil Measuring Tool and Sensor Expert? Answer questions, earn points and help others
