Question about GE Advantium SCA1001HSS Convection Microwave Oven
GE Advantiumk 120 - Complete Blackout Model Number: SCA 1001 HSS 01 Brand: GE Age: 1 - 5 years Thanks a lot for your expertise. It's a total blackout mid cook cycle. The house breaker and outlet are fine. This GE Advantium Microwave/Convection Oven -- SCA 1001 HSS 01 -- is built into the old cabinet in a crazy way. I have decent access to the front, bottom and right sides but not the rest. Any chance I can check/replace the main fuse without removing the unit? This would save me 1,000 headaches. Someone mentioned on the phone it's possible to access through the control panel. What's the step by step for this? If the fuse is good what next? Where can I find fuse installation instructions etc... and diagrams? How difficult will this be for an untrained but motivated guy?
  • 4 more comments
  • tedd_determa Oct 03, 2009
    Do you have a dis-assembly diagram for Step 1 and something that would coach me through step 2 if it turns out not to be the fuse?
    0
    false
    18 pt
    18 pt
    0
    0
    false
    false
    false
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:12.0pt;
    font-family:"Times New Roman";
    mso-ascii-font-family:Cambria;
    mso-ascii-theme-font:minor-latin;
    mso-hansi-font-family:Cambria;
    mso-hansi-theme-font:minor-latin;}
    It
    sounds like I might be able to access that fuse while the unit is still
    installed, is that correct?
    Is grill screwed in from top down or can I just
    shift the grill to the left as you suggested in the last paragraph—
    Do
    you have an assembly diagram by chance?
    The
    filter board assembly fuse you describe … is that different than the fuse you
    describe in the first paragraph?
    The
    exploded view of the unit I found seems to show one fuse up toward the fan and one in
    the upper right front. I understood that the one in the upper right front was
    the main one and likely the culprit… Am I mistaken?
    0
    false
    18 pt
    18 pt
    0
    0
    false
    false
    false
    font-size:12.0pt;
    Thank you for your thoughts and warning. 1 - Do you have a
    diagram by chance? Would make this easier. 2 - Why do you think my warranty is
    still good? I was told I have one year, nothing more…3 - If it’s not the fuse and I am not under warranty what is the
    likely problem and why is it dangerous if it’s simply replacing a piece and
    reassembling carefully? Thanks, Tedd
    did you guys try to post me a diagram? i have an important question because i am driliing through from the top of the cabinet so not to take dwn... how many screws hold the grill? tedd
    I was pretty disappointed in the advice so far. These fellows might have been trying but they didn't respond directly to my questions, they were vague enough that it's as if I had no advice and they did not answer in a timely fashion today and now I need to push this off another weekend and upset my tenants. How do I get a refund?
  • tedd_determa Oct 04, 2009
    Hey, I have missed my deadline to get this project complete and I am left with postponing the fix and upsetting my tenants or bringing it in to be repaired. No doubt you are a real expert and have the solution but now I am doing family stuff and then back into my work week. Who do I contact to get a refund?Thanks, Tedd
  • 3,267 Answers
Are you aware of this as stated below:
For T1 yr GE Will Replace:
Any part of the oven which fails due to a defect in materials or
From the date of the workmanship. During this full one-year warranty, GE will also provide, original purchase free of charge, all labor and related service costs to replace the defective part.
Second through The heating system, if any heater or lamp fails due to a defect in Third Year materials or workmanship. During this full three-year warranty, GE will From the date of the also provide, free of charge, all labor and related service costs to replace original purchase the defective part.
Second through The magnetron tube, if the magnetron tube fails due to a defect in Tenth Year materials or workmanship. During this additional nine-year limited From the date of the warranty, you will be responsible for any labor or related service costs. original purchase. Fuethermore visit Fixya's manuals of this equipment is freely download and has schematics with explanatory guidelines.........sodeep
Posted on Oct 04, 2009
  • GE Master
  • 13,433 Answers
Email premium.support@fixya.com
Posted on Oct 03, 2009
  • 3,741 Answers
The fuse is located on the control panel which is at the back of the base.and control panel, is located at the top.the fuse is not on the control panel its located on the control board.you will just have to remove the oven.this is the only procedure.but once the unit is removed then its not to tough.the sides are just fitted by screws.as replacing the fuse from control board also called main board is very simple.you just need to pull the fuse out by a plyer/clipper or with a thin knife.fitting is also easy there is a fuse holder.just keep the fuse on the holder and slowly press the fuse without applying force.it will fit easily.the cost of fuse is near to $3.you can get it from ------ www.radioshack.com ------ if the fuse is ok then its time for new main board. you can get the parts from www.partselect.com ------------------- this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Oct 02, 2009
  • charlymonty Oct 03, 2009
    there is a fuse inside the oven - located behind the control panel You may have to remove the grille on top to gain access to the screw that holds control panel on . If you follow the incoming wire from the cord it goes to this fuse , snap in type about inch long and 1/4 inch around.
    Use a voltmeter and check from both sides of the fuse to ground ( a metal screw) on the appliance . If you have 120 volts AC on both sides then the electronic board has failed.
    There is a filter board assembly in these machines that does have a 20amp one time fuse. However i will say that normally this is not the problem with these. That fuse normally will blow due to the main control board. The fuse is bnot that hard to get to thou if you want to check it. From the top of the unit remove the screws holding the front top grille in place. Then holding the grille slide it left a little this will unlock the grille and then you can take it right off. From there the fuse is mounted on a little board on the right hand side of the microwave. You will see it towards the top of the unit mounted to the inside wall.
    thanks.keep updated.
    President:
  • 1,734 Answers
There is a filter board assembly in these machines that does have a 20amp one time fuse. However i will say that normally this is not the problem with these. That fuse normally will blow due to the main control board. The fuse is bnot that hard to get to thou if you want to check it. From the top of the unit remove the screws holding the front top grille in place. Then holding the grille slide it left a little this will unlock the grille and then you can take it right off. From there the fuse is mounted on a little board on the right hand side of the microwave. You will see it towards the top of the unit mounted to the inside wall. However if you find that this fuse is good, since the unit is new i would call your number in your owner's manual for service. Microwave's can be very dangerous to work on, any thing beyond the fuse call a professional. The unit is still under warranty. Either you can check the fuse or call the manufacturer and have the tech when he comes show you where it is.
Is there something that is safe for me to spray/apply that will help loosen a door switch that sticks on a GE Advantium 120 Oven?
No, I would replace the switch. See this page.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | GE Microwave Ovens
Display reads... "control panel locked" how do I "unlock?"
The owner's manual will address any child lock.
If you don't have you r manual, maybe it;s a GE brand, since you posted in a GE category?
You can download GE owner's manuals and installation instructions here.
If it's not a GE, feel free to contact me directly with your brand and full model number form the tag in or on the unit for more free help.
A hard reset may work. Unplug it for a a couple of minutes, then try again.
If it still doesn't work, it may need a new keypad. Feel free to contact me directly (with brand & full model number) for more free tips or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 27, 2009 | GE Advantium 120 Convection/Microwave Oven
Button names wearing off
No, sorry. You'd have to order a new control panel assembly.
For model number SCA1001FSS001 it's part # WB07X10439 for $66.15.
You can find helpful exploded view diagrams and order it by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium readout flashing
I would say it is a sign of trouble.
Not to say that it's catastrophic, but on these models part can be pretty expensive.
We regularly repair such control units for customers nationwide by mail for in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
F3 error code GE 120 Adventium Oven Model SCA 1000 HWW 02
F3 means you have a shorted switch on the key assembly circuit board.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 25, 2008 | GE Microwave Ovens
No display, no power, complete blackout
Yes, the fuse is bad. Be sure to use a ceramic fuse of the same current (Amps) rating.
They're available at appliance parts stores, hardware stores, Lowe's, Wal-Mart, etc.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 28, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
Jul 29, 2007 | GE Advantium SCA1000H Convection /...
Advantium 120 Complete black out
Since you've already checked the fuses, my next suspects would be the thermal cutouts (or thermostats or thermal fuses, depending on your exact model number). One would be located on the right side of the chassis right above the magnetron. The other would be located on the left side of the chassis. It's the flame sensor. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Advantium 120 is not actually the model number - you have to look on the tag around the door or inside the cavity for that. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk I appreciate your thoughtful rating.
Apr 15, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA1001HSS Convection Microwave Oven Logo
248 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
