Need schematic for carrier furnace/ac. A butcher
Need schematic for carrier furnace/ac. A butcher tried to fix and switched wires. Original problem was that the a/c wouldn't work. The furnace guy changed wiring and had to come back with his boss the next day. They finally got the a/c working, but now, 2 months later, the fan won't come on and the furnace shuts off on high limit.
  • Josh White May 11, 2010
    Need model and serial number.
  • 89 Answers
There should be a schematic inside where the blower is or in the main elec. panel on unit
Posted on Nov 03, 2009
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
What wires go into the headlight switch
Replace the old switch
Don't be a butcher
Aug 31, 2014 | Cars & Trucks
Replace contacts in ac rheem 060jaz split system were is reset switch
Get wiring schematic check wiring and the restet is turning breaker on and off to unit. Furnace included. Start checking for 24v . To contractor and through pressure switches. 208-230 volts in unit. Beaware
Sep 06, 2013 | Heating & Cooling
Wiring diagram for carrier HK42FZ011 circuit board
Wire for wire if you are a novice. The schematic should be on the blower door just in case you get lost. I myself have changed hundreds of them and just undo the wires since I know where they go.
Jul 17, 2012 | Carrier Furnace Control Circuit Board...
I have short in my 24v power line in my carrier ac/furnace
Hello, usually visuall inspection is the first thing I would do, may times the wires will short at the outside condensing unit or at the indoor control board. If you cannot see it visually then run a continuity test on the wires with a multimeter. To fix a short sometimes it is easiest to just run new wire.
May 04, 2012 | Carrier Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Problem with carrier heat pump
Check the relays on the main board of your blower/furnace. If one is stuck, then the unit will not change from ac to heat. You may need to replace the entire board.
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
385 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
