Question about Garden
I think govenor is missing something.engine runs great but revves way too high do you have a diagram? model# 4-24975
  • 235 Answers
Check on the throttle arm for where the full speed adjust bolt is - many people back this off to get more revs to work faster .
Posted on Jan 02, 2010
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Honda XR200 revs up and down while in high RPM or higher speeds
You are on the right track with the fuel system. Maybe the fuel filter, There is one in the tank also, I think. Try running on reserve if you have it.
Apr 01, 2014 | Honda XR 200 Motorcycles
Honda xr 200, revving up and down during high rpm and higher speeds.
if not a float level or jet problem
worn carby
ebay sellers have them
Apr 17, 2017 | Honda XR 200 Motorcycles
Stihl ms200t revs up on it's own when running out of gas
Unfortunatly when any saw starts to run out of fuel the mixture leans off so the revs will increase, i can think of no way to stop this other than re filling before it runs out, ignition govenors only control the max high revs so would not help here, the new Husqvarna top handle saw with auto tune should address this issue.
Mar 14, 2013 | Garden
Engine idoling way to high
An engine will idle too high because of : improper govenor setting, improper carb setting, intake leak, or missing carb throttle plate.
Oct 24, 2012 | Briggs & Stratton Starter Scott's Equip...
Engine when started, runs over RPMs that it's designed for
The spring acts as an engine govenor, i would say the spring is not connected properly, if you have too much tention on the spring you will increase the revs.
Mar 18, 2012 | Garden
My engine revs on high by itself and runs rough
we had the same problem with our snowblower. we tried everything. ponits, adjustments. even converted points to electronics. we ened up putting on a brand new carborater and it runs great now. save youself the headaches and buy a new carborator. we spent $87. so much better
Dec 30, 2009 | Sport & Outdoor - Others
HOW DO I TIME THE GOVENOR I JUST PUT IN A NEW ENGINE AND SOMETHING IS NOW WRONG WITH CARB IT WAS GREAT ON OLD ENGINE DIDNT CHANGE ANY SETTINGS OR ADJUST ANYTHING BUT NOW NO FUEL TO SPARK PLUGS AND IT POURS...
The govenor has nothing to do with fuel pouring out.
When you say you put in a new engine- was it the same model/ type/ spec as the old one?
Maybe we should focus on the carb part.
Dec 20, 2009 | Diesel Farmall Tractor 560,460 Gas & ...
Would like to see diagram of 1986 isuzu trooper's engine
if it runs great...leave it alone and just maintain it, enjoy.
Nov 17, 2009 | 1986 Isuzu Trooper
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
