Leak in washing machine
Top loading washing machine. there is water leakage from the bottom of the machine. the belt gets wet and does not spin.
  • 2 more comments
  • nisha j Dec 21, 2007
    u have not solved my problem,u said that this is a generic problem
    cant u solve my problem
    then what is the use of all this , u just want e.mailid thats it
    go to hell
    Sergeant:
    Champion:
  • 362 Answers
Can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Posted on Dec 22, 2007
Water is splattering on floor during wash cycle. I took front off and it seems to be coming from the middle of washer and there was splatters of water on the front panel. there is not very much water leaking maybe a cupful
Posted on Sep 01, 2009
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
My washer is leaking bad and does not spin all the water out
there may be a blockage in the waste water pump had a similar problem with a beko there was a rubber band wraped around the outlet fan
Jan 23, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Kenmore Special Edition Top Load Washer - model # 24692300 - clothes are still quite wet following spin cycles. Machine appears to spin at a reasonable speed. HELP!!.... Thanks
Hi, Could be as simple as a slipping belt, they can get glazed, stretch or even get wet small water leak, and get the tub spinning but not fast enough or taking to much time getting going fast that the washer timer says it should be done and goes into the next mode. If you have no Idea how to repair the belt or check by looking under the machine after you unplug it, the only help is the repair person.
Nov 23, 2011 | Washing Machines
Will not ring out clothes, still wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 19, 2011 | Maytag Atlantis MAV6000 Top Load Washer
January 31, 2010 Kenmore top loading series 80 leaking from bottom toward front. It started during a wash cycle. I put two wet towels back into the empty washer and put on spin, leaking reoccurred. ...
is the pump leaking?or you could have bad tub seals,follow the center trany shaft up to the tub and see if it leaks there,is it noisy when spinning,you gotta just get in there with a light and look around to see where the water is coming from,if you sent pictures they didn't show up,remove the front cover,take out the two screws that hold the console down,remove the two clips with a screw driver and unplug the lid switch wires and pull the cover back and remove it
Jan 31, 2010 | Washing Machines
Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
Jan 02, 2010 | Washing Machines
Mav7000 spins but does not extract well. Clothes remain wet
wet as in standing water left in tub, or wet as in extra drippy???
standing water would be bad or pluged pump, drippy would be bad belt, pulley or tensioner assembly..
also if pump turns hard or has seized, the seal/bearing may have seized, causing a slowdown in spin speed besides burning the belt, leaking, and making a mess..
best of luck,
ttfn
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
