Question about Sharp Microwave Ovens
Door will not open. Above range. Model over 20 years old. Only number I can find is behind the air filter.
Neighbor who has the problem is not home for me to get the status.
Thank you
Posted on Oct 03, 2009
Need to replace door handle for Kitchenaid over-the-range microwave, Model: KHMS2050SSS - 0
You usually get better search results by leaving off any dashes or spaces in a model number.
Normally you have to separate the door panels (as shown in the photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful literature and exploded view diagrams with part numbers here and you can order parts from the Pros here.
May 21, 2013 | Microwave Ovens
JVM231WV001
It sounds like instead of an overheated magnetron thermostat tripping the power, you now have a defective door switch.
Our door switch help file is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2012 | GE Profile Spacemaker Over-the-Range...
How to replace door handle on whirlpool microwave model MH2155XPS-0
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance. A replacement part number for the model you have listed is 8169738.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 21, 2011 | Whirlpool MH2155XP Microwave Oven
Where can i get the Dishlex ranghood filters that more than 20 years old ?
The following Australian site carries Dishlex parts. You will need to know the model number of your rangehood or the size of the filter. If you know the model number simply do a more specific search to narrow your choices.
http://spares.alliedappliance.com.au/search.php?match=&keyword_list=Dishlex+rangehood+filter
Feb 15, 2011 | Microwave Ovens
Ge spacemaker xl-1800 microwave shuts off if used longer than 3min.
That would be model "JVM1540SM1SS".
This is due to overheating of the magnetron.
Attached to the magnetron is a thermostat, which opens to interrupt power if the heat gets too high. Then when it cools, the thermostat closes, restoring power.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
At
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 02, 2010 | GE JVM1540SMSS Microwave Oven
Microwave will appear to lose power (display goes dark; internal light goes dark) intermittently and inconsistently upon opening the door. Seems to be especially likely when oven has not been touched for a...
You probably have a bad connection either on the control circuit board (which we repair), the line filter board, or one of the thermostats.
Nov 20, 2010 | KitchenAid KHMS2056SSS Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Handle came unscrewed. I am a 70-year old retired woman with basic good sense and ability to follow instructions with most tools. Is this something I can do or should I need to call someone to correct? ...
Replacing or tightening the door handle is a repair that any Do-It-Yourselfer should be able to accomplish. The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
Aug 15, 2010 | Microwave Ovens
Door won't open
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
If yours is a DMT2420 or other counter top model that is built into a cubbly hole and surrounded by a metal grille (built-in kit), the kit will have to be removed, then the oven will slide out of the opening.
Once it's out, you can remove the outer cover and you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
The model tag will either be on the back or around the door frame or control panel frame, or maybe inside the cooking cavity.
We have several Dacor microwave service manuals at our site:
It's a pain, but for Dacor the parts list are separate:
Once you have the part number of the part you need, you can order by part number here.
(This site does not list Dacor by model number, only by part number)
Aug 03, 2009 | Dacor DMT2420SS Microwave Oven
Microwave not functioning
The fuse is usually located behind the control panel, sometimes near the switches, or on the chassis floor. In some models it may be mounted in the line noise filter.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Maytag MMV5165 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
