Question about SuperMicro X7DAE Motherboard
X7DAE at the time of boot stuck on logo
Fresh parts assembled, mother board supermicro X7DAE compatible ramm nvidia En7300gs (tried another also) using single proc quad core xeon , 600 watt PSU, when start it detects drives then stuck on super micro logo with saying DEL to enter setup.... but DEL key does not work and after few seconds keyboard hangs.. it happening with 2 motherboard same config both having smae problem .. any idea :)
  • sahir74 Dec 23, 2007
    this problem is solved thanks for helping me , upgrading bios allowed me to have 5410 series proc on X7DAE
  • 31 Answers
The broblem is probably your keyboard, since del doesn't work then this indicates that your keyboard could have some wires cut from inside the wire casing due to various reasons or the keyboard plug isn't well attached to the wires or have some bent pins.
my advice : go buy a new keyboard.
Posted on Dec 22, 2007
X7dae compact flash
Make sure the Compact flash card is set "Active" as well as formatted
Dec 10, 2013 | SuperMicro SERVER_MB SMICRO|X7DAE-O I5000X...
I have XEON Core Duo processors with Dynatron heatsink fans attached. One of my CPUs is running about 8-10 degrees hotter than the other one and if I let it idle they both heat up until the alarm sounds...
Hello try to download the manual here:
http://www.supermicro.com/products/motherboard/xeon1333/5000x/x7dae.cfm
The fault could be a wrong setting in the bios chipset or cpu option.
Maybe one of the cpu has a wrong mhz setting ( overclocking )
This will make the system unstable.
75 degrees celcius is too hot even for a intel cpu.
Try to reset the bios to factory settings.
And look also for an bios upgrade.
WARNING!
Please do not download / upgrade the BIOS/Firmware UNLESS your system has a BIOS/firmware-related issue. Flashing the wrong BIOS/firmware can cause irreparable damage to the system.
Remember to add new cooling paste, not much, when removing the cooling element and fan.
Good luck
Jul 31, 2013 | SuperMicro X7DAE Motherboard
We just purchased Supermicro 1026T-URF SuperServer: X8DTU-F motherboard. Added Intel X25-E Extreme (Ephraim) SSDSA2SH032G1 2.5" 32GB SATA SSD drive and attached a SAS storage via Areca...
Make sure the DVD is plugged into the left most SATA connector on the motherboard. ( I-SATA0 )
Make sure SATA1 is set to "Compatability" in the BIOS.
Do not use "Enhanced" for SATA1.
Make sure the Primary IDE setting is CD/DVD in the BIOS.
Do not use "Auto"
On the USB problem, Make sure Legacy USB is disabled in the BIOS.
WARNING! The default is, Legacy USB " Enabled".
Apr 01, 2011 | SUPERMICRO COMPUTER Supermicro X8DTU-F...
I installed a Radeon HD 4350 video card and the computer stick on the Supermicro logo on bootup
unplug the new card and retry,,
if it works without the card then take the card back to the store
Mar 12, 2010 | SuperMicro X7DAE Motherboard
The i need to disconect somthing because i cant see anithing wen i conect the port to the card but wen i buthem back to normal i see my monitor
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Nov 21, 2009 | SuperMicro NVIDIA GEFORCE PCI-E 5300 VGA...
Best heatsinks
cooler master heat sinks are the best
Jul 08, 2009 | SuperMicro X7DAE Motherboard
Will not boot past Logo screen with new XFX nvidia Gforce 9500Gt 1gig card
DD SYSTEM SOLUTIONS
(MOTHER BOARD CHIP LEVEL SERVICE CENTRE)
OLD NO.28, NEW NO.67, II FLOOR
SESHA CHALAM STREET, SAIDAPET,
CHENNAI - 600 015.
PHONE NO : 98405-11595
Apr 30, 2009 | Intel D915GUX Motherboard
Mother board freezes on abit logo wile starting....
Hello Carlos,
Did you open the powersupply and check? I have recently worked on a PC with a similar fault and I found that the circuit board is partly charred and couple of capacitors leaking. I advice that you check it and post back..( I can't forget that repair coz I got one hell of a shock while working on it)
Sai.
Mar 02, 2009 | Abit Computer-model:AN78GS Motherboard
I have a supermicro processor x7dae with a row 0 channel 1 fault.
3a
Remember to replace the DIMMs in pairs unless you have an exact duplicate spare.
Jan 13, 2009 | SuperMicro X7DAE Motherboard
SuperMicro X7DAE Motherboard Logo
171 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
