Question about Refrigerators
Area between doors is warm
There is a 2 inch stip between the 2 upright doors thet is warn to the touch. Is this normal ?
  • 4,059 Answers
No it's not. It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan. Here's how to test the fan. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Oct 02, 2009
Seals on my beco are hot to touch fridge freezer feel warm
Almost the same post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Fridge runs all the time
Hi and welcome to FixYa, I am Kelly.
Since you did not provide a model number... this will be a generic / not unit specific answer.
Running all of the time can be caused by several things. Two of the most common reasons is either the condensor fan area in the lower back of the unit has a problem. (lint, fan not running) or the evaporator fan in the freezer is not running. (Fan, ice build up on coils stopping fan)
If the unit is not defrosting properly the evaporator coils freeze up and air can not pass through the coil area. This results in the freezer beening cold and the fresh food compartment to slowly warm up.
Open the doors of your unit and touch the facing area where the door gasket seals. I should be warm to the touch but should NOT be very warm to almost hot. If it is very warm / hot to the touch it will confirm my comments above.
UNPLUG the unit
Clean the condensor area in the bottom of the unit. Use a crevice tool and something NOT sharp, NOT metal and NOT pointed to clean the coils. Old paint brush, big cable tie etc. Make sure the condensor fan is running after you plug the unit back in. A note on powering up any refrigerator.... anytime power is remove you must wait 15 - 20 minutes for the coolant system to stabilze or the compressor will not start.
If you note ice build up in the freezer compartment do a manual defrost by unplugging the unit, placing a fan directed at the freezer compartment (less freezer contents) for just over 2 hours. It makes a water mess so be ready to tend to drips and puddles. After 2 hours and clean up.. return the unit to normal service.
After doing the above the unit should operate normally for at least 2 days. If it continues to operate normally great. If after a few days it starts acting up again suspect that the automatic defrosting function is not working properly and have the defrost system checked.
Thanks for choosing FixYa,,
Kelly
Dec 12, 2010 | Frigidaire Refrigerators
Door gets warm
Warm is normal hot is not. Too hot is an indication that the condenser coils are overheating due to being dirty or a bad fan motor. See the link below for details I put together on this. Let me know if it helps.
Hot Condenser
Jun 03, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My whirlpool gold side by side is extremely warm bordering on hot when you touch the upright section between the fridge and freezer, (where the doors meet)
As long as it doesnt affect cooling operation, this will be normal. There is a heater in that area meant to keep the door gasket from building frost. Without it the door gasket wont properly stick giving you that air tight seal.
Mar 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire frostlfree upright freezer ice forming top interior door
Not sealing. warm air hitting cold air causing frost. also, door frame heater may not be working. most frames are "warm" to the touch. normally called an "anti sweat" heater.
Jul 15, 2008 | Freezers
Kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Warm to Hot molding that seals the doors
The heat in door frame is normal but undetectable when ref at normal temp. Definitely cooling problem. Google ref not cold enough to get help to solve problem. Never use any oil for it will not help also health problem if not approved to be used around food. Fan motor must be replaced for it will just keep stopping.
Mar 31, 2017 | Kenmore 52642 / 52644 / 52649 Side by Side...
Freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Nov 02, 2007 | Freezers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
