Fujitsu Lifebook laptop will not turn on
Fujitsu Lifebook Laptop Model A6025 will not turn on, fan starts and green operating lights flash. Only remedy is to leave motionless for days and only then will it start again, and if I move the laptop while its running it shuts off. Any thoughts?
    President:
  • 2,600 Answers
It is one of two things and that is hard drive or motherboard. To see which it is, take the hard drive out and start the computer. When it starts, tap the F2 key, if the computer gets into the BIOS and you can make changes, then I would venture to guess the problem lies with your hard drive.
Posted on Oct 02, 2009
How to activate touchpad on fujitsu lifebook modela6025 a series
Go the Device Manager under Control Panel and make sure it is not disabled. Right click and select enable. If you see a yellow exclamation mark next to it means the driver has not been installed and you will have to download and install it.
Jul 17, 2014 | Fujitsu LifeBook A6025 Notebook
Can i upgrade my network adapter on lifebook A6025 to 80211.N?
To upgrade to wireless N you would have to use a wireless N usb adapter from like lynksys or netgear
Jun 28, 2014 | Fujitsu LifeBook A6025 Notebook
Fujitsu a6025
Have you checked the air vents? (inlet and outlet, also the fan itself) If they are dirty, you can clean them up using canned air. Blocked air vents may cause overheating and the laptop shuts down in minutes.
Mar 10, 2014 | Computers & Internet
Fujitsu Lifebook c1410 froze
plesae check your hardisk, and also check your ram,
Nov 30, 2011 | Fujitsu Lifebook C1410 Notebook
Wont take 4 gig mem
Can you post the exact model and specs of your laptop? Usually every laptop has its maximum RAM limit that it can hold.What OS are you using? If your laptop's specs says that it can hold to a maximum of RAM of up to 4gb, then you might have a problem when youre using win7 32 bit because it will just read out 2.99gb. You can upgrade it to 64bit and you won't have any problems whatsoever.Hope this helps. Reply back and have a good day.
Oct 04, 2011 | Fujitsu LifeBook A6025/C Notebook
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
My laptop keep turning off
If turns off after booting, then there may be problem in the Operating system or may be virus problem or may be problem in the battery also. To confirm, remove the laptop battery directly connect to ac then try. If it works OK then it's with battery problem. Or else may be problem in the power supply section or Operating system or may be virus problem Try this, if still problem is there, then plz do let me know.
Jan 18, 2011 | Fujitsu LifeBook A6025 Notebook
Computer turns on but screen stays black and key is unresponsive
You need to reformat your PC...try reinstalling your operating system
the boot loader might be infected with a virus
alternative:
Maybe you have a hardware problem:
Battery and AC adapter failure - replace if needed
Thanks. Cheers!
Apr 20, 2010 | Fujitsu LifeBook A6025 Notebook
Lifebook A6025 left touchpad button not working. How do I fix? I believe it is worn out.
1. You may be correct
2. If the unit had been dropped the connector inside could be loose. This will require you to do an invasive look at the unit.
3. The pad switch can be replace but it isn't for the novice to disassemble and reassemble.
4. Some touch pad have a flex cable that attaches it to the main board or mother board.
5. You can purchase a usb mouse that you can use. They are pretty cheap now and continue using the laptop.
Mar 23, 2010 | Fujitsu LifeBook A6025/C Notebook
Computers & Internet Logo
830 people viewed this question
David Payne
David Payne
