Question about Dishwashers
Timer stuck on dry
The timer on my dishwasher is stuck on dry, it wont do anything else onther than that
  • 1 more comment
  • drewmanchu Mar 08, 2008
    My dishwasher has a similar problem. I upgraded cabinets and re-installed the dishwasher. The timer gets stuck towards the end of the wash cycle. Would shutting down power at the circuit breaker help reset it? Or will I need to have the parts replaced.
  • scrapteach May 20, 2008
    Mine also gets stuck just before the final drain. I have been manually moving it ahead so that it can drain but it doesn't seem to dry.
  • Anonymous Dec 29, 2008
    Brand new in condo just bought. Unit might be over a year old, but never used. Turned on in morning, came home at nighttime and still running!  Help!
I have Miele electronic G562 dishwasher which gets stuck in cycle exactly on 1/2 way main wash when the water is is comming in can i fix it myself?
Posted on Feb 09, 2009
  • 833 Answers
Bunny, you don't say if this is a mechanical or electronic timer. If it is mechanical and you can access it, move the timer by hand. It may be all that's needed. If you can't do that, the unit will have to be changed out because the motor is bad or the contacts are damaged. If it is electronic, cut power to the unit at the breaker for a few minutes and repower. If this doesn't do it, you are going to need a timer board. Let me know.
Posted on Dec 22, 2007
Frigidare dishwasher ..dead!
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 68690bea-e43a-408a-beaf-ff3b0809599a.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
Maytag dishwasher starts too easily and gets stuck in wash cycle
see this causes and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 28, 2012 | Maytag MDB7100AWB Dishwasher
Stopped working-stuck in the dry cycle
Your timer motor is shot. It's located in the control panel behind your selector dial. Go to ebay or any of the parts suppliers and with the model number, you should be able to pick one up. Make sure you unplug the power when doing any work on it.
Apr 20, 2012 | Dishwashers
Timer will not advance, stuck on "Clean" blinking light, will not do anything else
Your control has detected an issue with the heater circuit. You may be able to reset it by performing the following "button dance." Press the buttons in order within 5 seconds to reset the control.
Hi Temp Wash Air Dry Hi Temp Wash Air Dry
You may have Energy Saver Dry, but it is the same thing. If it does the blinking clean light again, look closely at the heater for burn marks or breakage.
Kelly
May 25, 2011 | Dishwashers
Dishwasher runs for appx 14 min & stops washing half way thru wash cycle. Timer contunies to run. No drain pump out (nothing). Let dishwasher set idle for appx 1 hour and it will re-set. Set timer...
This sounds like something is stuck in the drain pump. You can remove the inner cover to look for obstructions. You have a dual purpose motor it does the both circulating and draining. The blockage is causing it to overheat and trip the thermal protector. You can remove the drain assembly from underneath if you don't find anything from above. There is a video at www.appliancehelponline.com/servicemanual.html that walks you thru most of this. It is a different model but pretty close.If you find no obstructions the motor may be failing.
Apr 08, 2010 | Whirlpool DU840CWD Dishwasher
Hotpoint DF23: Wont go through full cycle
Sounds like you may have to replace the cycle timer.
Oct 28, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
377 people viewed this question
Top Dishwashers Experts
