Question about HP Compaq Presario V2000 Notebook
My mother had the computer plugged into an apartment wall jack . and had been using it a while that day.. all of a sudden the computer screen went White. she tryed to shut it off but it wouldnt.. so she took the battery out.. put it back in and turned it on. the screen wouldnt display anything lights light up u can open the cd drive and put cd in and it sounds like its running but nothing happends.
    President:
  • 2,600 Answers
Why won't my magic jack work plugged into the wall outlet?
Magicjack uses the internet. It has to be hooked up to a computer using the internet. Its just skype for regular phones. Skype is free. magicjack cost 20 bucks. its a scam
Oct 27, 2014 | Cell Phones
Why will my magic jack work plugged into the wall outlet?
This is a common problem with the magicjack. It works when plugged into a USB port on the computer, but not when plugged into an AC wall socket.
Problem:
The separate power converter module has failed.
When the magicjack is plugged into your computer USB port, it is getting power directly from the 5 volt source in the USB port.
In order to use AC wall current to power the magicjack, a power converter module is needed. That module contains a transformer and rectifier that coverts 115V AC into 5V DC. That module is no longer supplying 5V to the magicjack.
Tech section - you can probably skip this part:
The problem is poor quality low ESR electrolytic capacitors in the power module. ESR is Equivalent Series Resistance. A low number is good, high is bad. The ESR of a capacitor is measured with an ESR meter.
The 5V output of the power module measured only 3.5V. I took the power module apart to to trouble shoot. I found two 220uF 10V capacitors that were labelled "Low ESR" (C8 and C9). I measured the ESR of these caps and C8 measured 1.5 Ohms. I replaced the C8 cap and it fixed the problem. 5V output was restored.
Solution:
I do not recommend repairing these power modules. I did it out of curiosity. These modules are very cheap.
Magicjack is aware of the problem and offers a replacement. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
will-magic-jack-work-plugged-into-wall-mbz13odsyguuiirp1214tyyc-2-0.jpg will-magic-jack-work-plugged-into-wall-mbz13odsyguuiirp1214tyyc-2-1.jpg
Oct 27, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
My Sanyo TV was plugged in, I was watching it and all the sudden the screen went gray wash, then it cut off. You can plug it in the wall and it will try to cut on but cuts off after like 2 seconds. It also...
U have a soldering iron,solder?Now basic soldering?Unplug the tv wait about half an hour for the highvoltage to disapear.Take the tv aparts.Resolders the Video board that connected to ur CRT Tv tube.Resolders all those coldsolders pins sockets pins on the video board,will solved this problem.Have fixing these problems many times on the CRT Tube computer monitors,when it was still popular.
Sep 09, 2010 | Sanyo Televison & Video
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
HP dv6000 screen is blank
Video chip failure on the main board join the hundreds with the same problem need a new mother \Board and it may still happen again to that one
Dec 09, 2008 | HP Pavilion dv6000z Notebook
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Laptop sudden poweroff randomly
I googled "fujitsu laptop forum" and read a couple of posts and it may be an AC input jack problem. If the computer does this without the battery and only AC plugged in then you could assume it's not the battery or charging circiuts. Some laptops get mother board problems but that was not what I read. It wouldn't hurt to go to http://forum.notebookreview.com/forumdisplay.php?f=7 and post your problem. good luck.
Sep 24, 2008 | Computers & Internet
Philips Go Gear hdd075/17 stopped working suddenly!
Why not simply try charging it up, I assume it came with a charger? Other than that I do not know
Oct 15, 2007 | Philips HDD070 MP3 Player
HP Compaq Presario V2000 Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
