Question about Jura Capresso C1500 Espresso & Coffee Maker
Capresso C1500 My machine got into this problem where it signals for: "Water cycle needed" but no water will get out but I can here the pump working. I opened it to check the final output hose to check for clogs but its open and dry. I replaced the water filter and even tried without it with no luck. Any suggestions? Thanks, Ronen.
I have tis same trouble now no water at all I need help fast
Steve
Posted on Dec 15, 2009
    Problem Solver:
  • 9 Answers
You need to let water run through the system. What has happened is the heating unit has dried out. Treat the machine as if you just took it out of the box...(check your directions for the steps) basically all you need do is fill with water, turn the water nozzle on and let it run a bit. Water will refill the heating unit as it runs through. That will fix the problem and you'll be back in business.
Posted on Mar 31, 2010
3 Suggested Answers
  • 4 Answers
SOURCE: Capresso C1500 "Water cycle needed" Problem
Have you tablet cleaned it?
Posted on Apr 23, 2010
  • 3 Answers
Hello, I know it's been a while since you asked the question, but I ran ito the same problem this morning. I got so frustrated that I vigorously wiggled the knob from 0 to hot water, back and forth, until it sounded like the "normal" water flow sound. And voila, it works again!
Posted on Dec 12, 2011
My C1500 has started leaking water out the bottom. I think it is coming from the right-hand side, but not sure. It doesn't seem to be coming from the tank and it is coffee-colored water. Any...
I'm working on the same problem, I need someone who reads technical swiss-german to help. There is a pump on the bottom right that drives cold water into the boiler. The connector on the bottom of the boiler (brass to vinyl plastic) came apart on mine. On a german language expresso maker website there are several parts that address this problem, the difficulty I'm having is figuring out which part fits tthe boiler I have as apparently this is a problem on serveral version and there have been re-designed connectors (mine doesn't look exactly like the one in the picture
http://www.kaffeemaschinendoctor.de/ReparatursetsWerkzeug/Dicht-/Reparatursets/Jura-Reparatur-Dichtset-fuer-die-Heizpatrone::101.html
Jul 18, 2011 | Jura Capresso C1500 Espresso & Coffee...
Have an Impressa S Avantgarde Series that will not fill with water. The unit has not been used for about a year
The Operating Instructions for your machine can be found here:
http://www.capresso.com/pdf/inst_s9a.pdf
Are you getting any Error Messages? Refer to the Troubleshooting Error Messages on page 30.
Is the low water flotation device in place and working?
Suggest you walk through the instructions for Preparing the Machine for the First Time on page 11.
Pay special attention to the water filter cartridge as I suspect this will need replacing, page 18 & 19.
You may also need to run a decalcification cycle, page 28, to make sure deposits have not plugged the machine.
There is a Quick Reference Guide available for your machine which you may also find helfpul:
http://www.capresso.com/pdf/ref_s9ot.pdf
Feb 28, 2011 | Jura Capresso Impressa S9 Coffee...
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
It leaks clear water underneath on right side
Hi, wondering if you found the solution, my S9 is doing the same thing. Thanks
Feb 04, 2010 | Jura Capresso C1500 Espresso & Coffee...
I have a jura capresso S7. I am finding water in
This is normal, after each cycle the brew unit will empty the drainvalve for excess water, this will ensure that the water used for each new cup is fresh from the watertank.
Jul 14, 2009 | Jura Capresso Impressa S90 Espresso...
Water does not come out the frother/hot water spout .
check your solenoid valve and security valve of boiler of the machine. make sure they are clean and work good, than you will have perfect espresso again.
if pump runs without your comand check up the swich of brewing coffee.
Mar 31, 2009 | Jura Capresso C1500 Espresso & Coffee...
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Feb 26, 2009 | Jura Capresso C3000 Espresso & Coffee...
Jura Capresso C1500 Espresso & Coffee Maker Logo
410 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
