Question about HP DeskJet 5550 InkJet Printer
The check numbers are printing in reverse order
It prints multiple pages in reverse order. How does one change that so that Page 1 comes out on top.
Most inkjet printers print the first page on the bottom, second page on top, etc. To get the first page on top, you can check the "print in reverse order" in the printer setup dialog.
Jul 21, 2015 | Brother MFC-J470DW Inkjet All-In-One...
How do I get the printer to print the first check number first
IN THE PRINTER SET UP YOU CAN CHANGE HOW PRINTER PRINTS THIS IS ON YOUR COMPUTER HP SOLUTION CENTER, PRINT LAST SHEET FIRST OR JUST THE OPPOSITE, HOPE THIS HELPS....
May 06, 2014 | HP OfficeJet Pro 8600 Plus Printer 3042823
How can I reverse the order of printing pages?..I have a Cannon and MAC
When you click print, and IF a Print Window opens, then it should allow you to click a button on that window to change the Print Properties. There should be a choice for "reverse order" and you just need to unclick that choice.
Oct 21, 2012 | Canon Office Equipment & Supplies
Would like to reverse order of printing
Go to Print properties and you will find an option which says print last page first. Check that box and it should print the documents in reverse order.
Thank you for choosing Fixya
Nov 09, 2009 | HP Office Equipment & Supplies
Checks printing in reverse order
Generally speaking, there is a setting on your print drivers properties to print reverse order. Start, Printers, right click on your printer, go to printing preferences and it should be there.
Aug 28, 2009 | Sharp AR-5320 Black and White Copier
Reverse printing
Open your printers/faxes folder, right click the printer you want to change, select properties. In that window, click on printing preferences. Click on the next to last icon (should be an A with a red arrow going to an upside down A). On that screen is an option to reverse print. Click on it.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | HP Business Inkjet 1200dtn Printer
XEROX 2424 is printing in reverse order
Check your driver settings, in Layout option some people things that print in reverse order is going to print on both sides but its not. It wil print your job backwards though. So make sure you dont have that selected
Oct 20, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
I need to change printing pages from last to first page first
the last printed page is always on top. For a long document, it takes a while to resort and place the first page first! This is how you can get Microsoft Word to reverse the print order and save all the trouble.
I have spent so much time resorting documents after printing. On my printer, the last page printed is always on top. By printing the last page first (reverse order), the document is already correctly sorted.
Here is how to do it:
1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
Now, all your documents will prevent in reverse order. What a lifesaver!!!
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
C4180 HP All in one printer
Check the following steps:
Open the control panel and Right click on the printer icon and select printing preferences.
Select Layout option and check for front to back option and click OK.
Regards,
Sagarjd
Aug 27, 2008 | HP Photosmart C4180 All-In-One InkJet...
Reversing the print
You can check/uncheck the box "start printing from last page" in : Start - Printers and faxes - Right_Click_PSC1410 - Properties - Printing preferences - Features.
Aug 31, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
