Question about Dell A920 InkJet Printer
My Dell 920A only prints half the page and its 90 degrees out.Can you tell me what he solution is?
3 Suggested Answers
  • 232 Answers
SOURCE: printer only prints half of page
My printer does this when the paper isn't seated properly and/or that paper guide isn't set correctly. If this all seems OK, then try a head clean. You should be able to do this from the printer options in Windows.
Posted on Dec 13, 2009
SOURCE: dell p1500 printer when printing a page, half
HOLA NECESITO EL SOFTWARE DE LA IMPRESORA DELL P1500 ME URGE CONSEGUIRLO LLEVO MESES BUSCANDOLO POR FABOR AYUDA........
GRASIAS
Posted on Dec 31, 2009
Scanning half a page
You will need to check your page settings. As each program is different, the page setup will generally stay the same. It will also change if you are scanning at 0, 90, 180, or 270 degrees as well.
Mar 04, 2014 | Canon DR-7580
Tally genicon 6605 is printing from top to bottom of the page...what could be the problem
I think it depends on what you mean by printing from top to bottom of the page.
If you are describing the print being rotated by 90 degrees so rather than a line of print going across the page from left to right, the print goes up and down the length of the page.
The most common cause of this is that you are printing from a Windows application and you have set the page orientation to LANDSCAPE rather than PORTRAIT.
With in the application you are printing from look for the PAGE SETUP options ensue you select PORTRAIT.
This should rotate the print.
Oct 18, 2013 | TallyGenicom Office Equipment & Supplies
HP LaserJet 1020 PATCHES ON PRINT OUT
if the patches are random, and not ghost images duplicating down the page, you may need to take out the toner and gently shake it - tilt it right 90 degrees, then left 90 degrees, etc a few times to redistribute the toner...
failing that, the toner could be almost empty.
otherwise, check and see if they are duplicating down the page.. ie the same image defect 3 or 4 times down the page, if so, it is probably one of the drums.. toner or fuser drum...
Hope this info helps.
May 15, 2012 | HP LaserJet 2550L Printer
I need to tighten the bolts on the head what is the difference from lbs and degree. example 22lbs and add 55 degree.
I know...screwy way of doing it but what you do is torque to the specification then turn the wrench 55 degrees more (hint : 1/4 turn is 45degrees, half turn is 90 degrees, one full turn is 360 degrees etc) So on your example you would torque to 22lbs then turn it a bit more than a quarter turn past where you stopped at 22 lbs.
Jan 31, 2010 | 1999 Chevrolet Blazer
Dell p1500 printer when printing a page, half
GRASIAS
Dec 30, 2009 | Dell P1500 Laser Printer
Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Aug 20, 2008 | Dell 926 All-In-One InkJet Printer
Prints partial picture
You have to rotate the pictures 90 degrees if they are landscape before printing.
Jun 10, 2008 | HP Photosmart 4180 All-in-One Printer
Printer only prints half a page
I have a Lexmark 5400 series printer that is only printing the top half of a page. Any suggestions anyone ?.
Jan 20, 2008 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
61 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
