Question about Elkay Plumbing
Replace ELkay tub/shower faucet in wall
I would like to either replace or put new cartridge in 20 year old Elkay Tub/shower valve without cutting it out of the wall. Possible?
Ken
5 Suggested Answers
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
gary1121
  • 332 Answers
SOURCE: wobbly faucet on new elkay sink
this faucet comes with diffrent hold downs for diffrent sinks on is wider for stainless sinks the other is smaller for granite or corian sinks, it sounds like your plumber might have put the wrond spacer under the facet where it mounts to the sink,, it doesn't matter the sink or the faucet they all come with proper adapters, and I do know that moen and delta have them in the box with the faucet,,, good luck with yo people, this faucet of yours even comes with the plastic tool to put the faucet in because it has a long shank with threads on it and is hard to get a wrench on
Posted on Jun 07, 2009
  • 82 Answers
SOURCE: I just installed a Glacier Bay tub/shower faucet
Hopefully you still have the directions - the diverter isn't set correctly.
Posted on Dec 31, 2009
Elkay kitchen faucet model lk7124 replace stem
ELKAY ' Strainers, Fittings + Other Accessories for the Home
www.elkay.com/strainers-fittings-other
Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
www.elkay.com/
Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
[PDF]SPECIFICATIONS
aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-ArcĀ® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
www.amazon.com > ... > Faucet Parts
Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
Elkay A51947R Replacement Diacore Cartridge with Brown ...
www.amazon.com/Elkay...Replacement.../B0033UX8...
Amazon.com, Inc
Jan 14, 2016 | Elkay Plumbing
How do i remove the stem from an Elkay kitchen faucet model # LK7124?
Leaky Elkay single handle kitchen faucet - DoItYourself.com ...
www.doityourself.com/.../292646-leaky-elkay-single-handle-kitchen-fau...
Can I replace the cartridge (A54236R) from our single handle Elkay (LK-6360) kitchen faucet without removing it from the sink top? If so where is the secret inhex ...
Need to replace a gasket or cartridge inside the faucet. How to disassemble?
Call Elkay they will ship you the cartridge @ no cost should have LTW
Dec 11, 2010 | Elkay ILGR6022RC Gourmet Triple-Bowl...
Hello. We have a Moen two handle tub/shower faucet. A little over a year ago it started to make a high pitched noise when on. Now the water flow to both the tub and shower are greatly reduced for BOTH...
sounds like the diverter inside the valve body is cloged with debris.
only wat to remedy this is to remove the valve and clean out the diverter, or just replace the valve.
Aug 05, 2010 | Moen 2919 Chateau Two Handle Tub and...
30 year old Elkay bathroom one handle faucet is leaking from underneath. Does this use a replacement cartridge and how can I get a replacement part?
If it does have a cartridge, replacing it would only help it stop dripping out the faucet or from around the handle. A leak underneath is most likely to be a failure of the seal from the supply pipe to the faucet, from corrosion and/or hardening of the rubber seal that is part of the supply pipe connection. Shut off the supply. (Hopefully you have a shutoff valve under the sink.) And remove the supply pipe/tube/hose. This is very hard to do without a basin wrench. (All hardware stores have them, and they are pretty cheap.) Take the supply pipe to the hardware or home improvement store to select a replacement. Other than the material and construction of the pipe itself, and the length, there are only a couple of different fitting configurations.
May 08, 2010 | Elkay Plumbing
All in one tub and shower has a leaking tub faucet, how do i take the whole all in one tub and shoer out, and how do i fix the faucet to the tub then put shower and tub back in(all in one piece).
When I went to take mine out I had to cut it in half. Before doing anything drastic are you sure there's no way you can excess the plumbing from the other side of the wall? Its a lot easier to patch drywall than pull a tub. The faucet and pipes should be attached to the studs in the wall and not really attached to your tub. I don't really know what part of your faucet is leaking.. Some parts you should be able to excess from the front without pulling your tub. If its from the down spout you could probably loosen a screw or allen head that's on the bottom pull it off replace it or replace the O'ring inside. I hope I have help out.
Mar 04, 2010 | Moen & One Handle Tub & Shower Faucet
How do you remove the cartridge from a LK2454
Call Elkay and they will give you instructions. Thanks anyway.
Jan 05, 2010 | Elkay Plumbing
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
American Standard Cadet model 3275 - Plastic piece inside of pipe
Yes, there is a non-replaceable plastic restrictor device screwed into the tub spout outlet of the faucet body. It's purpose is to force the flow down to the spout for when the spout diverter is not closed. It keep water from rcoming out of the shower head when the tub spout is also discharging.
This is all fine and dandy where the water supply is clean without sediment. A co-worker of mine had one of these and old galvanized piping. After 3 years, it clogged up. She got a 'deal' from a handyman plumber to replace with an identical faucet. She will have the problem again. If she had spent the money to fix it right, she would have had a single handle mixing valve put in. If it clogs, you can just pull the cartidge from the body, clean it and put it back in. Now she will have to cut into the wall again, get the plumber to replace the 2 handled unit and patch the wall again.
Or, she could have the plumber drill out/remove the restrictor but then she might get water out of both outlets at the same time....."pay me know or pay me later"....repalcing the mixing valve with a scald prevention single handle valve (with remodel plate) is the BEST long term solution.
Fred Grable
Chicago
(Engineer and Ex-Master Plumber)
Mar 22, 2009 | American Standard Colony 3275.505 099...
Hi varn4620,
Thank you,
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Plumbing Logo
528 people viewed this question
Top Elkay Plumbing Experts
jdthefixer
rdjagger
Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
