Question about Refrigerators
Our 10 yo Sub Zero 632 started leaking water out of the bottom of the refrigerator side recently. The water appears to be coming from the hose that runs behind the salad crisper. How do we fix this?
  • 454 Answers
The water is probably from the defrost cycle. Normally, this water is collected in a trough under the refrigerator and a fan blows across it to make it evaporate. Your trough has apparently overflowed.
It may also be coming from the freezer. When the drain line from the freezer clogs or closes with ice, the condensate will run down inside the refrigerator.
Posted on Oct 02, 2009
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
Hi. My Sub Zero 632 is dripping water from the bottom corner of the freezer door. Can you tell me what the problem is and how I might fix this? Thank you so much.
It does appear that your side by side refrigerator has an ice maker, so that rules out any extra water from a faulty valve.
I think the seal on your freezer door may be broken/torn.
Usually there is no water (per se) in the freezer, but as things thaw, or as the door is opened it can create condensation that leaks. The freezer will retain cool for a while but eventually things will thaw out and water will leak.
Please check the thermostat for the freezer, and make sure there are no containers leaking in the fridge portion.
Good luck.
Sep 26, 2010 | Sub-Zero 632 / S
Sub zero 632
3C on the fridge side
-18C on the freezer side
Sub-zero repair in Orange County, CA
Jan 30, 2010 | Sub-Zero 632 / S
Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Sep 30, 2008 | Sub-Zero 632 / S
Sub-Zero 511 Freon Leak
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Sub zero #590
Have a small water leak up top on left hand side and looks like it could be a small plastic hose?
Dec 25, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub zero side by side
evaporator leaks freon, made a video on how to replace it
Oct 09, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
