Question about kawasaki 840168 Green 150 Pc Rotary Tool And Accessory Set
Kawasaki Rotary Tool is missing the square collet nut
I recently purchased a Kawasaki rotary tool with a flex shaft and the kit did not include the required square collet nut to drive the flex shaft. Would anyone know where 1 could be purchased.
The kit should have a selection of collets, there is one that works with it in the selection that can replace the brace collet that is in the flex shaft head
Posted on Oct 12, 2009
  • 2,176 Answers
I am working on getting a website for this company, but you can try Alltradetools.com and see if they have anything, they distribute them.
Posted on Oct 03, 2009
I can't get the small sanding disc out of the tool.
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
Aug 11, 2011 | Craftsman Single Speed Rotary Tool
How to replace the spline and coupling
The coupler nut tends to be screwwed on so tight that even when undone, the collet has bit into the soft shaft of the tool. Holding the rotation lock button in, grab the shank with some strong needle nose pliers and twist the shaft loose or pull it off completely with the nut and then seperate the nut from the shank when it is out of the Dremel Tool. A lot of machine tools are tightened too much, which makes the shanks get all damaged so use only the required tension on that collet nut.
Mar 28, 2011 | Dremel Variable - Speed Multipro Rotary...
Dremel 300 Series - I can't get a collet to go in the shaft. looks like something the same size is in the shaft but is not proturding to pull it out. Unable to wedge it out.
There is a collet stuck in there. It was probably in there without any tool in place, then the collet nut was tightened. With no tool filling the hole in the collet, it collapsed and became small enough to be pushed too far in. Fortunately these collets are soft steel. Find a sheet metal screw that you can screw into the hole. That will allow you to pull the collet out. Discard that collet. These collets come in at least two sized to accommodate different sizes of tool shafts. Unfortunately the spare one you have is one of those sizes, and the one you extracted is probably the other. But they don't cost much and you can buy them where you buy dremel tools. Good luck, Al K
Feb 02, 2011 | Dremel Variable - Speed Multipro Rotary...
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
I have a collet nut that will not loosen. at one point while turning the shaft lock button pops up; even when pressed
Sorry, but I seem to have ( essentially ) the same problem... no positive lock. holding the button down while rotating the shaft to find the "best hold" then applying extra pressure sometimes helps. I had no problem with an older model. 400 XPR also seems to overhheat badly.
My ultimate solution: purchasing the model 4000.
Apr 25, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
Jul 09, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Can't find replacement collets/locknut for PowerSmith rotary tool
Hello Bob, I recently saw your post about the Power Smith PS2103. I have this same tool, and have never been able to use it because the collets don't fit the bits.
I was looking at it recently - I have the owner's manual - and although there is no web address, there IS a toll free help line. Here is the number - 888-552-8665
I called the number - got their voice mail, left a message, but they have NOT returned my call!
The only outlet that MAY carry this brand is Zellers, but I haven't been there yet.
Good Luck!
Bob (in Canada)
takemoff@shaw.ca
Jun 10, 2009 | Tools & Hardware - Others
Using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 02, 2008 | Dremel Variable - Speed Multipro Rotary...
kawasaki 840168 Green 150 Pc Rotary Tool And Accessory Set Logo
296 people viewed this question
Top kawasaki Tools & Hardware - Others Experts
Are you a kawasaki Tool and Hardware - Other Expert? Answer questions, earn points and help others
