Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD My Book Not Recognized
WD 500GB added yesterday to Mac G4 running OS X 10.4.11. Backed up data with MacBackup. An hour ago, the drive began running w/o being accessed. Could not eject the drive. Restarted Mac. Drive goes thru initialization, but is not recognized (lights on front flashing). USBs check out with other drives. Swapped USB cable w/o help. Disconnected power supply. Waited 2-3 min and reconnected. No joy...still not recognized.
I have sensitive data on the drive. I have it backed up remotely too. So no worries about lost files. But, if I exchange the drive on warranty. Is there any way to remove it?
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Oct 02, 2009
Wd passport 500gb only works in mac. i need it to work in other computers
It could be that it's formatted with an HFS+ filesystem, which is not natively recognized in windows. Open up the disk management and check the filesystem on the device. If it is HFS+, you can get it to be recognized by getting all the data off, formatting it with another filesystem (FAT32 or NTFS are recommended), then putting the data back on.
Jul 12, 2011 | Western Digital 500GB My Book Pro-External...
Well i bought my first hard drive(WD) yesterday 10-25-10 and when i plug it into my mac power book G4, its not recognized. I went to utilities to try to format it. I see the hitachi drive and the Macintosh...
if you are trying to install through usb then check if the usb you are using is working try to connect a flash drive on the same usb and try of use the other HD on that usb and see if it gets detected if no then uninstall the usb drivers from device manager and restart the system and it will work and it will get instaled automatically
Oct 26, 2010 | Western Digital My Book Essential 500GB...
My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Jul 10, 2009 | Western Digital 500GB My Book World...
My portable hard drive is not recognized by my Mac G4 power book
You have to run mac tools that is on that hard drive prior to plugging it in.
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
WD 320GB portable Hard drive not recognized by my powerbook G4
NTFS file system on Hard drive .
http://www.macyourself.com/2012/03/11/how-to-format-a-drive-for-mac-and-pc-compatibility/
Nov 26, 2017 | Western Digital My Book Essential Edition...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
Hard drive not being recognized
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Aug 24, 2008 | Western Digital 500GB My Book World...
PROBLEMS WITH MY WD BOOK
Hi, This post might be of some help/idea... http://www.fixya.com/support/t191153-device_recognized The only difference is your model uses Western Digital and not Seagate. Yours can still be recognized but Windows consider it non-formatted. First try a data recovery software and another storage medium where you can copy the files if you're successful in the recovery. Good luck and kind regards.
Aug 28, 2007 | Western Digital 500GB My Book World...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
915 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
