Question about RCA D52W15 TV
Plug the tv on and makes a spark kind of noise
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: tv sparked and made noise and shut off rca model f32648
This a flyback problem defected already replacing a new one with identical rating ,then it works normal again.
Hope it may help you;
Posted on Jan 28, 2009
1996 safari sounds like it sucks to much air and instantly smells like gas
What kind of noise? Did you change the distributor cap and rotor? Do you have a wire laying on the exhaust manifold?
Aug 11, 2012 | GMC Safari Cars & Trucks
My ultra classic has engine ping
Hi Anonymous, and the usual suspects are:
1. Fuel octane rating too low.
2. Faulty spark plugs.
3. Incorrect spark plug for the kind of service.
4. Excessive carbon deposit on piston head or in combustion chamber.
5. Ignition timing advanced due to faulty sensor inputs (MAP, CKP, CMP)
Good luck.
Aug 06, 2012 | 2001 Harley Davidson FLHTCUI Electra Glide...
How to fix van with no spark on 1997 ford areo star van 3.0 liter
Honstly what you need is a starting point dosen't realy matter what kind of vehicle or engine you have . You say you have no spark. Pull the coil wire off the distubtor if its not a coil pack set up so if you have adistubitor cap this is the wire in the center of the cap . Have someone crank the engine over while your holding the main wire about 1/2 inch from where it plugs into on the cap you might want to ware a rubber glove . Do you see a spark . If not then the problem must be before the plugs wires or distuibor cap and must be in the electronic ignition or before that .On the other hand if you do see a spark and it should be kind of a blue spark and make a snap noise thgen the power is getting to the cap and the problem must lie beyony this point and be related to the cap or rotor plug wires or the a bad plug . At any rate you will have to think about and test it if you can do it you will save lots of money
Mar 23, 2012 | Cars & Trucks
My car will not start...it has gas. It turns over..it just wont start.
Sounds like a broken fuel pump, or it could be a coil, have someone crank the car, and you stand by near the gas tank, when the ignition is opened, you should hear a winding noise by the fuel tank, thats the fuel pump running, if no noise, then more than likely thats your problem.
Aug 23, 2011 | Mercury Sable Cars & Trucks
Mpy TV makes a popping noise for about 30-45 seconds when you first turn it on, then stops. Is this a bad horizontal output transistor?
If this is a CRT type TV, then I would check for cracks in the flyback transformer. In a darkened setting, you should actually be able to see the sparks jumping to the frame from the transformer.
Replacement of the transformer is the ultimate solution, but you may be able to seal the crack with silicone sealant (like the kind used for fish tanks) until you can find a replacement.
If you can't see the sparks, it could be sparking internally, and simply must be replaced.
Jul 31, 2011 | Televison & Video
Its a 1998 528i bmw that will start but wont stay running also there is a loud kind of backfire noise from one of the cylinders . the engine wont rev up proper even though i keep pressing the throttle...
The fact that you have a backfire noise that you can trace to just one cylinder makes it sound like a spark plug could be loose or broken. Pull out your spark plugs and examine them. On a '98, that eill mean pulling off the plastic cover, then removing the coils (need a 10mm socket, be careful with the ground wires) and then reach down in with a small spark plug socket on a long extension.
Also, look for a massive air leak on the intake. Take apart the air tubes from the air filter up to the throttle body looking for air leaks. You could also have a leak at the intake manifold gasket but you may need help to check for that.
Mar 25, 2011 | 2008 BMW 528i Sedan
Picture has disappeared!
Ur high voltage is dead,the FBT,the flyback transformer is not transfer voltage.The big block of plastic with a red wire with a cap to the CRT(tv tube).That thing is dead.
Sep 28, 2009 | Televison & Video
Tv sparked and made noise and shut off rca model f32648
Looks like the projection is fried. I'm afraid you would have to exchange for new one if you can or purchase new Tube.
Jan 28, 2009 | RCA F32648 32" TV
Jumping Screen
I've had a couple of these. The panel control board is going bad, but there may be a way to make it last a bit longer. If you go into the MENU of the TV, and turn off all the color correction, all the whistles and bells that come inside the tv to "make the picture better," it usually helps. Any kind of motion correction, or any kind of noise reduction (picture noise reduction) should be turned off. If the picture has a cloud of green pixels that seems to pepper the screen, then after you turn off all the stuff in the menu, unplug the TV for 5 minutes, and then plug back in. It should help the picture some.
Hope this helps...
Jan 05, 2009 | Insignia IS-LCDTV32 32 in. Television
RCA D52W15 TV Logo
152 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
