Question about Estate TEDX640JQ Electric Dryer
Drum does not turn,not very old ,cannot access inside
  • Estate Master
  • 7,482 Answers
Sounds as if you have a broken belt.
If your machine is a front loading machine, then you would normally access the belt by removing the front of the machine.
This will expose the drum and belt, if you remove the drum, then it will expose the rollers, idler arm with pulley, and motor.
I hope this helps
Posted on Oct 03, 2009
Testimonial: "Thank You So Much, I can use all that and anything else you can send my way!Very Helpful!"
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Mar 26, 2016 | Samsung DV218AEW Electric Dryer
Growling noise when drum turning
That could be the motor roller or drum rollers gone. You need to take off the front top to access inside. Take off the top first, then remove the control panel, then the front. You may need service person to help.
Sep 07, 2013 | LG DLEX3875V Dryer
Can't get brake drums off
You have to back off the shoes. Look for a rubber plug on the bottom of the backing plate. Remove this plug to access an adjustment wheel. To back off the shoes you will need two tools. One to hold the lock foot off the wheel and another to turn the wheel. You can make these tools from a old metal coat hanger and a flat blade screw driver. Cut the coat hanger about 6 inches long, bend a 90 deg hook on one end about 1/2 inch. you need a screwdriver about 7 inch's long. Get you a good light so you can see inside the drum and see the lock and push it away from the adjustment wheel, while your turn the adjustment wheel with the screwdriver to get the shoes away from the drum. Then once you have clearance between the shoes and the drum you have to hit the drum with a hammer to free any rust that holds it in place.
Aug 28, 2011 | 2004 Suzuki XL-7
Have an old hotpointdryer model no 9321w the drum will not spin when door is closed i have to move drum by hand to make it spin, is there a capacitor on this model or somthing else that starts the drum...
Yes there is a start capacitor on this model, it is usually located at the rear right of the inside of the cabinet, so you will need to gain access to the inside of the dryer.
Feb 19, 2011 | Hotpoint Dryers
I have the GLEQ212ES1 dryer. When it is running. it sounds like something is rubbing against the drum. When you turn it by hand manually, the drum is harder to turn.Could a piece clothing gotten stuck...
Although this is possible, usually one of the wheel bearings may have gotten dry or even is stuck. Inside there are wheels that the drum is steadied by and that rotate with the drum. If it's a year old it should be under warranty and a tech can fix it. If that is a problem, remove the back (after unplugging it) find the wheels and rotate the drum by hand. If a wheel is stuck or dry you will find it. I hope this helps.
Jul 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Money stuck inside drum making noise
The easiest way to access the area between the inner and outer drums is to take the front off. Instead of something being in the drum making the noise it may be the front felt pads that the front of the drum turn on. It makes the same noise. They are replaceable.
Jun 19, 2010 | Washing Machines
Drum rubbing on inside walls
Go into the back of the dryer. Remove access to back and you will see the drum. Chances are your motor that turns the drum is loose or the shaft or spindle that the dryer spins on is loose from its bracket. Tighten all that up and it should be fine.
Jan 30, 2009 | Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Have a "finshing" noise even when drum stops a turn
I had a similar problem and found a screw had backed out on one of the turning paddles inside the drum but the screw was on the under side , and could reach it through the access door , just had to turn the drum by hand till the screw was in sight.
just turn the drum inside by the paddles and shake them to make sure they are tight , thats how i found my problem and noise
good luck hope this helps , wayne t
Jul 14, 2008 | Dryers
Washing machine
It might be a bearing, or it might just be something inside the drum!
If the machine is not exceptionally old it shouldn't be a bearing.
It might be limescale!
You can access and inspect the drum from the outlet.
Heres what to do:
Disconnect the machine from the mains and the water supply and pull it into a clear area.
Put a thick cloth on the floor and gently lay the machine on its left hand side, looking from the rear,
Undo the small panel on the back and you will see the black rubber concertina hose, pressure chamber and pump, which are now all easily accessible from the rear and the botom of the machine.
Undo the circlips with a screwdriver and pull the hose away from the drum. You will now be able to see the element and the inside of the drum.
Check it for debris and limescale.
At the same time clean out the filter with its "ping pong ball" and plastic pressure chamber.
THis will clear out any loose items and let you check to see if the drum needs descaling.
Job should take about 20 minutes!
Feb 19, 2008 | Hotpoint Aquarius WD640 Front Load...
Estate TEDX640JQ Electric Dryer Logo
61 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
